Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    #81
    Re: Panasonic P50G20E
    Yes
      Perhaps then we need a V20 service manual, then, to see where fan line goes so we can disable it. I'll ask around.
      • Stanislav
        • Dec 2012
        • 135
        #83
        Thank you Tom
        • Stanislav
          • Dec 2012
          • 135
          #84
            OK, I am now lost. How did you do that? What sorcery is this?
            • Stanislav
              • Dec 2012
              • 135
              #86
              it's magic TOM
              after turning on the TV there is a pause of 10 seconds before turning off.
              pressed minus the volume and menu from R.C and showed this
                So does it work at all, as I do see a self check failed?
                • Stanislav
                  • Dec 2012
                  • 135
                  #88
                  It makes diagnosis and then turns off
                    I think 2nd FE / 3rd FE might be a fan error.
                    • Stanislav
                      • Dec 2012
                      • 135
                      #90
                      Тоm with this board I can get into the system menu for 10-20 sek ,from there that can be said whether to have or not fans
                        In which case, tell it to not have fans then...
                        • Stanislav
                          • Dec 2012
                          • 135
                          #92
                          do not give me change it
                            Does it let you set it, perhaps, for G20 chassis?
                            • Stanislav
                              • Dec 2012
                              • 135
                              #94
                              No.
                              I have no time to consider all,TV turns off very quickly
                                Can you show me what options are available?
                                • Stanislav
                                  • Dec 2012
                                  • 135
                                  #96
                                  not enough time,the left is the main menu and from there are submenus
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    #97
                                    Tom my friend you will not believe what I found see photo
                                    http://www.hifi-forum.de/bild/panaso...20e_14329.html
                                      A V20E with fans? So they DO exist. Very odd! Is it me, or do the fans go to the SS board?
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        #99
                                        No, they go to the A board
                                          What's under OPTION in service menu?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
