Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    #121
    Re: Panasonic P50G20E
    What is external box
      A cable receiver, you know, like you'd use for a TV that didn't have cable built in.
      • Stanislav
        • Dec 2012
        • 135
        #123
        OK I understand . It really is suited for a different standard of digital TV.
        More importantly it works perfectly . I made a little improvement in new board ,I added another cooler
          Neat -- are you going to add fan? The SC and P boards are really the only ones which need good fan cooling. I seem to remember the G10 as being quite thin so cooling was restricted.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
