Panasonic P50G20E
  • Stanislav
    • Dec 2012
    • 135
    • Bulgaria
    #81
    Re: Panasonic P50G20E
    Yes
      Perhaps then we need a V20 service manual, then, to see where fan line goes so we can disable it. I'll ask around.
      • Stanislav
        • Dec 2012
        • 135
        • Bulgaria
        #83
        Thank you Tom
        • Stanislav
          • Dec 2012
          • 135
          • Bulgaria
          #84
            OK, I am now lost. How did you do that? What sorcery is this?
            • Stanislav
              • Dec 2012
              • 135
              • Bulgaria
              #86
              it's magic TOM
              after turning on the TV there is a pause of 10 seconds before turning off.
              pressed minus the volume and menu from R.C and showed this
                So does it work at all, as I do see a self check failed?
                • Stanislav
                  • Dec 2012
                  • 135
                  • Bulgaria
                  #88
                  It makes diagnosis and then turns off
                    I think 2nd FE / 3rd FE might be a fan error.
                    • Stanislav
                      • Dec 2012
                      • 135
                      • Bulgaria
                      #90
                      Тоm with this board I can get into the system menu for 10-20 sek ,from there that can be said whether to have or not fans
                        In which case, tell it to not have fans then...
                        • Stanislav
                          • Dec 2012
                          • 135
                          • Bulgaria
                          #92
                          do not give me change it
                            Does it let you set it, perhaps, for G20 chassis?
                            • Stanislav
                              • Dec 2012
                              • 135
                              • Bulgaria
                              #94
                              No.
                              I have no time to consider all,TV turns off very quickly
                                Can you show me what options are available?
                                • Stanislav
                                  • Dec 2012
                                  • 135
                                  • Bulgaria
                                  #96
                                  not enough time,the left is the main menu and from there are submenus
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    • Bulgaria
                                    #97
                                    Tom my friend you will not believe what I found see photo
                                    http://www.hifi-forum.de/bild/panaso...20e_14329.html
                                      A V20E with fans? So they DO exist. Very odd! Is it me, or do the fans go to the SS board?
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        • Bulgaria
                                        #99
                                        No, they go to the A board
                                          What's under OPTION in service menu?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • dajoker
                                            Panasonic th-p50s10d - blinky red, SC board go boom
                                            by dajoker
                                            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                            I chased my way through the PSU, and a board, with no results.
                                            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                            I only have the right half of the picture.
                                            Left half is completely blank.
                                            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                            all the other voltage rails...
                                            09-24-2024, 04:39 AM
