Vizio VO47LFHDTV10A burnt spot on PSU, replace or try to fix?
Re: Vizio VO47LFHDTV10A burnt spot on PSU, replace or try to fix?
The replacement master inverter resolved the problem. The caps look good on the replacement and the picture is nice now. If anyone wants to challenge themselves to replace the blown IC on the failed master, let me know. They're selling for $15-30 on ebay. I also have an extra good slave inverter for this TV, with the shorter inverters, not the long ones.
Merry Christmas and thank you for the help.
DavidComment
First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheetHi all,
I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by irepair559hello guys I got these LEDs lights ( Power probe TEK ) 4 little cube Leds that go into a one unit holder /charger , that charges via 5v rail to all 4 at the same time.. but brother used a 12v and fried 2 of the 4 boards.. ..so only 2 work and the others just get hot and battery don't charge..
The boards consists of input of 5v then battery connector 5v out and a connector for the led ( 3 modes ) 5 wires..
I bought some 5v charging boards type c..
I can connect it to charge battery but how to connect the led 5 wire connector ?... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
