I picked this TV up from a friend after fixing a panasonic plasma. I have basic electrical troubleshooting skills, and am a teacher who is really good at following directions. Other than that, I'm a Newbie in terms of TV troubleshooting.
Basic symptom is that when plugged in, the Vizio icon lights up, but nothing happens at all when you try to turn the power on. Previous owners said they were watching and it just died.
From what I've been told, the problem is either the main board or the power board. I'm wondering about the procedure to tell which. That alone would be a big help, but if it was also possible to tell what on the board was bad, then I might even be able to fix it and save $100 for the main or $60 for the power board. I did some poking with my multimeter, and here is the data I have:
Vizio light is on, but nothing happens when the power button is pushed.
On the powerboard:
I have standby 5v from the three "ST/+5V" tabs on the powerboard to the main.
I have 12v at the three tabs on the same plug labeled "12v".
I have 2.4 v at the tab on the same plug called "on/off."
All the grounds on this plug are clean to ground.
The plug next to it with Dim, Inv Com, VBR_A, Status, AC Det, are all dead.
There is voltage from the main board to the standby light (of course) as well as 5v to the IR chip on the bottom corner of the TV.
I'm not sure if any of this helps, or if I'm even following the proper procedure.
If nothing else, to know which board to buy would be nice.
If I could figure out which component on the board was bad, and if it was replaceable, that would be even better.
Thanks in advance for any help for the Noob!
Matt.
On the powerboard:
Matt.
