phillips lcd keeps blowing fuse
  • TimT
    • Nov 2012
    • 268
    • us
    #141
    Re: phillips lcd keeps blowing fuse
    it says the part i got works with Philips LC407SS1 I have Philips 40PFL3505D/F7. The board look the same. same voltages printed on the boards are the same. the only difference that i can see are the diodes on the new board are larger " physically " around the bridge. im thinking about swapping them out. cant do no harm I can always use one as a core. MisterD I just dont know what to test on the power board. seems output is correct
    • TimT
      • Nov 2012
      • 268
      • us
      #142
      MisterD your board is the same as my orginal board " ba01p0f0133 "
      • MisterD
        • Oct 2012
        • 668
        Mine is ba01p0f01033
        • TimT
          • Nov 2012
          • 268
          • us
          #144
          its the same... I left out the 0
          • MisterD
            • Oct 2012
            • 668
            I doubt swapping out those diodes will do any good, I agree the output voltage is all there on your power supply, it seems that the inverter board is shutting down as soon as the backlights turn on.
            • MisterD
              • Oct 2012
              • 668
              Ok, that's the bare board number, mine has white stickers but they don't include a barcode and the numbers I have are probably Emerson. Do you see the white sticker with barcode on the chassis itself? That is the Panel Manufacturer and Panel Number, mine is Samsung LTA400HM09
              • MisterD
                • Oct 2012
                • 668
                I noticed that my inverter board is not using the small connector with the 2 wires, one black and one white, like yours has. I wonder if your backlights would stay on if you left that small connector unplugged?
                • TimT
                  • Nov 2012
                  • 268
                  • us
                  #148
                  tried that with no luck. will check panel#
                  • TimT
                    • Nov 2012
                    • 268
                    • us
                    #149
                    looking closer at the board installed it has a large cap then the old board did not! boards seem the same.the hole for that cap is on my old board but never installed! assuming this board can work for other models. a guess a " generic board " that can be setup for different tv's. also another cap is installed on the new board. i think i can setup the new board just like the old one. strange it seems this board as is has the correct output.
                    painel# LTA400HM01
                    old board A01PNMPW 05810P00557
                    New board has no sticker ...... BA01POF01035
                    • TimT
                      • Nov 2012
                      • 268
                      • us
                      #150
                      about the diode. it was not installed in the new board but was in the old. I left it out untill i tried the new inverter. when that did not work i pulled the diode from old board and installed it. but that did not seem to do anything
                      • MisterD
                        • Oct 2012
                        • 668
                        I see in post 92 that you are showing a picture of the way you tested the voltages from the power supply and the connector is Not plugged in, Please Make sure all connectors Are plugged in on all the circuit boards, leave them plugged in and test the BL-SW Voltage, if your probe won't make contact with the bare part of the wire you can use a safety pin by pushing it into the connector, check the voltage on both ends of the wire that goes from the power supply to the inverter board. with the TV powered on what voltage do you have at BL-SW connection?
                        • MisterD
                          • Oct 2012
                          • 668
                          painel# LTA400HM01
                          I had a replacement power supply board for a 47" Philips LCD that I was working on and it had a capacitor and one other component missing in comparing it to the old board but it still worked fine. since all the correct voltages are present I don't think that trying to set up new board to match the old one will remedy anything.
                          • TimT
                            • Nov 2012
                            • 268
                            • us
                            #153
                            tested plugged in and not either way 3v at BL-SW. and I agree with you more the one way to get the correct volatges. but this power board was not listed as a alternative to the orginal board. so i dont know....
                            • MisterD
                              • Oct 2012
                              • 668
                              I'm not sure where you got your Power Supply replacement board from but check this out, it says the replacement works with both Philips LC407SS1 and Philips 40PFL3505D/F7 depending on serial number.
                              http://www.shopjimmy.com/pandf-a01pempw-001-mpw-cba.htm
                              • TimT
                                • Nov 2012
                                • 268
                                • us
                                #155
                                it should work then... but I don't know what else to try anybody got any suggestions?
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  Here are the readings from the mainboard connector and inverter connector.
                                  main
                                  tuner 35v is getting 39v
                                  lcd 12
                                  lcd 12
                                  p+on 3.36v
                                  +6.5vf or 1v gets 11v
                                  p-on 3.5v or reg gets 6.70
                                  p+ on 5v
                                  24v for amp gets 27.8
                                  inverter
                                  power sel 0 "THIS SHOULD BE ABOUT 2.69 VOLTS" posted by MisterD 1/8/2013
                                  bl adj is not used
                                  bl 5w gets 3w
                                  error 0
                                  gnd
                                  gnd
                                  gnd
                                  gnd
                                  gnd
                                  24v
                                  24v
                                  24v
                                  24v
                                  24v
                                  not sure how to inturpet these results?
                                  there is a 10amp SMF on inverter and it's getting 9.6 on both ends. inverter lights up for a split second thats when i see the " phillips " when inverter goes out the phillips is still there. then I see the no signal. this is extremely hard to see! I can ajust the sound/channels ect it works fine. menu works fine. powers off and on correctly. seems everything works fine just no backlight.
                                  Look at this voltage again on the white connector on the power supply board.
                                  PWM-SEL you say 0 volts, budm says that controls lamp brightness, I checked that voltage on my 40" Emerson that has the same power supply board as your old board, I have 2.69 volts here on pin PWM-SEL you have 0 volts, maybe that's why you don't have any backlight, please check this voltage again, if it is still 0 volts and it was my tv set I would take two 1.5volt AA batteries and solder a short wire from + of one battery to - of the other battery, then take a clip lead wire and cut it into, solder one of these to the - of the one battery and then the other to the + of the other battery, so you end up with two AA batteries wired in series with leads on each end to give you a 3 volt power source, hook the - (negative end) to chassis ground and hook the + (positive end) to the PWM-SEL pin on the power supply white connector using a safety pin to contact bare part of wire and then power on the TV set and see if you have backlights.
                                  • TimT
                                    • Nov 2012
                                    • 268
                                    • us
                                    #157
                                    confirmed PWM-SEL is 0. are you sure about connecting -+ together? so just solder -+ at top and bottom " one battery will be upside down " then run two leads from each. any lead could be the ground?
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      It's like putting 2 batteries in a flashlight, the positive post from one battery touches the negative post of the other battery, the nipple end being positive and the negative end being flat, here's a picture diagram of two 6 volt batteries wired in series, just look at this as two 1.5 volt batteries wired like the picture and it will produce 3 volts, the nipples of the two AA Batteries would be facing to the left in the picture.
                                      Black in picture is Negative to ground, the red would go to the PWM-SEL
                                      • MisterD
                                        • Oct 2012
                                        • 668
                                        Do you have flux for soldering? applying flux to the battery ends where you solder wires will make the solder stick better, if not apply solder to the wires prior to soldering them to the batteries.
                                        "Heat the part not the solder"
                                        • MisterD
                                          • Oct 2012
                                          • 668
                                          If you want some other input from budm or tom66 before trying this I can private message them to get their opinion, I copy and paste the link to this page so they can click on it and come here to see.
                                          Update! I did send a message to them both asking for their input.
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • Bootleg1
                                            Samsung UN65KS9800FXZA T-con fuse blowing
                                            by Bootleg1
                                            Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                            02-04-2020, 01:05 AM
