LCD plastic filter sheets
  • ryan74
    • Oct 2012
    • 471
    • usa
    I just got a samsung 32in with 2 wide scratches but not that deep.
    I want a permenant fix(no Vaseline)
    Will removing the top plastic sheet mess with picture? I assume yes since it is a filter.
    Do i have to buff it out?
    Does anyone sell these sheets?
    Re: LCD plastic filter sheets
    If they are on the surface of the LCD they are not easily fixed, but one way you can fix it is to swap the internal layers so the scratched on is before the good one, this will make the scratch much less noticeable.
    • randtek
      • Oct 2011
      • 280
      • US
      I have no idea how old your TV is, but if the scratches are on the outer surface of the screen, there is probably nothing that can be done. I am not aware of any Samsungs that have a screen protector sheet in front of the panel, but I cannot say for sure. The front sheet of an LCD screen is a polarizer filter and is permanently affixed to the front of the LCD glass.. It is critical to the operation of the screen. Basically, if this is your problem, you can either live with the scratches or replace the TV. Replacing panels is rarely cost effective.
        master hoarder
        • May 2008
        • 12175
        You CAN actually remove the polarizer filter from the screen. Just Google "LCD privacy screen" or "privacy LCD monitor". However, once you do that, you will need to wear polarizing glasses to see the screen.
        • ryan74
          • Oct 2012
          • 471
          • usa
          I tried the eraser on screen and it worked. cant see scratch anymore.
          tried it on another tv with thin scratches and deeper and did not work.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Kemer
            Led status indicator light transfer plastic
            by Kemer
            Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
            There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
            The plastic piece doesn't appear to be broken.
            1. What are your suggestions for resolving this issue?
            2. Is the plastic piece made of special ma...
            08-19-2025, 07:02 PM
          • David Stroe
            AOC CQ27G2U/BK - in need of data sheets
            by David Stroe
            I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
            I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
            Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
            Main Board: 715G9500-M0C-B00-005K
            T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
            If someone could please provide any of these data sheets, it would be awesome....
            05-31-2025, 11:12 AM
          • jeybee
            surface pro 3 teardown. battery failure.
            by jeybee
            in the process of replacing the battery.
            managed to get the screen off without breaking it.
            used a solder station hot air set at 200 deg
            used a piece of aluminium from the bottom of the takeaway tray and a foot scraper blade that can be bought in most pound shops.
            starting with a cold device i heated up the screen slowly and evenly around the edges with the air gun. then concentrated on the area by the speaker, i inserted the foot scraper blade just under the glass, slicing the bonding glue and worked towards the closest edge, applying heat regular....
            10-02-2021, 11:44 AM
          • Raulnn
            clean hisense inner sheets
            by Raulnn
            Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
            01-22-2023, 05:19 PM
