surface pro 3 teardown. battery failure.
  • jeybee
    • Sep 2021
    • uk
    in the process of replacing the battery.
    managed to get the screen off without breaking it.
    used a solder station hot air set at 200 deg
    used a piece of aluminium from the bottom of the takeaway tray and a foot scraper blade that can be bought in most pound shops.
    starting with a cold device i heated up the screen slowly and evenly around the edges with the air gun. then concentrated on the area by the speaker, i inserted the foot scraper blade just under the glass, slicing the bonding glue and worked towards the closest edge, applying heat regular.
    managed to easily get it to lift and slide between the casing and the glass. applying heat often i the proceeded towards the camera applying ready cut sheets of thin plastic underneath the glass that had come away from the frame to stop it rebonding.
    i did a recipe of heat, slice with the foot scraper blade until i met resistance indicating the glue was setting, then followed it by placing the foil and then a sheet of plastic under the glass i had just cut away. inserting a new sheet of plastic as required working my way around the the next edge and bottom edge.
    i then returned to the speaker where i started, then worked my way around with the same method towards the bottom corner. the bottom length of the screen i took some extra care with but this turned out to be unwarranted as you can push something in, up against the glass at least 5 mm without touching anything and the glue doesn't go further than this.
    i ended up with the screen lifted all the way around and sheets of plastic between it and the casing preventing rebonding. then lifted the glass/screen away from the casing , cutting any glue still holding itself.
    i them removed the battery, touch and screen connections. reinserting the screws into the board to not lose the bridge connections.
    measured the battery connector and had 0v output.
    next i removed the black plastic warp off the top of the battery. to expose the 4 cells. each cell had 2.0v output.
    then cut the nickel connections with a blade on each of the batteries. peeled away the batteries one by one bending them in all sorts of nasty scary ways until they were all out.
    upon inspection it was clear the battery controller board had suffered some kind of damage. it appeared to be corrosion, green copper sulphate. and some of the smd components had the same. however no water damage ever to the device , the internal and external pristine condition proves this to me. so not sure if it was an electrical short that lead to corrosion or corrosion that lead to failure. the battery count shows 8 cycles.
    put it all away in a box and awaiting a new battery.
  • tongshadow
    Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
    by tongshadow
    I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
    "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
    Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
    03-12-2023, 12:06 PM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
  • shovenose
    Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
    by shovenose
    Got this one for free because, well, it no worky.
    A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
    Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
    08-11-2021, 01:26 PM
  • gsegpitd
    Asrock rx570 - sam001.009 - secure memory validation failure
    by gsegpitd
    I'm trying to diagnose my Asrock Phantom gaming D Radeon RX570 8G which produces an error 43 upon loading Windows drivers.
    "./tserver -boardtest=quickmfg" fails with message "sam001.009", which implies this is a "secure memory validation" failure.
    I can't seem to find any useful information regarding this failure, or this "secure memory" in general, on my own and am now under the assumption the gpu bga itself will need replacement (which is somewhat beyond my capabilities/comfort zone).
    Does anyone have any further...
    07-05-2022, 08:05 AM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
