My THIRD Insignia NS-32LCD!!
  • Paul678
    • Nov 2011
    • 402
    I was hoping this was going to be yet another simple power supply
    issue like the last two, but it was not to be.
    This time I used my oscilloscope to check the +24DCV and +5V,
    to make sure they were stable, and they were.
    The backlight was not working, even with the +24V there, but the
    "BLON" (back light on) pin was at zero volts, so I jumpered
    this pin to +5V using a 1k ohm resistor, and the lamps turned
    on, working just fine, but the screen was a blank black screen,
    because the main board wasn't displaying anything, no menu
    or anything.
    So it's pretty clear it's a main board issue:
    "BLON" (back light on) pin is on the white connector on the right most, bottom
    corner. I measured some of the resistors in the lower right corner at +3.3V, but there
    were also some areas that measured a weird +16V. WTF??????
    But most of the advice here is for SMPS, inverters,
    fuses, and caps, but not so much advice for fixing
    main boards, so I ain't holding my breath, but just
    in case someone knows something about this board,
    I'm naturally all ears......
    But it looks like it's Ebay time, yet again!
    Re: My THIRD Insignia NS-32LCD!!
    There are several DC-DC converters and voltage regulators. I have had the DC-DC converter fail on a similar Harwa chassis, which caused the TV to lock up then not power on after being turned off.
    • cajoeg
      Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
      by cajoeg
      Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
      The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
      02-10-2025, 04:01 PM
    • valvashon
      Insignia NS-LCD19-09 (third and final post, hopefully!)
      by valvashon
      I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
      Problem was no cold startup; it would only startup when you applied a heat gun to the board....
      10-22-2025, 12:33 PM
    • Diah
      Samsung UE50J6150AS BL_TON OK Screen only little corner lighting up
      by Diah
      i got this TV today.. as you can see the screen LCD had only at the corner lighting up, the other round light spot are lens falling down on LED as i can hear it when i move the TV.
      i tell the truth i never seen this before.. LED BL yes are little blue but i don't thing it related to this issue as i suspect the T-CON, i saw before T-CON when it work the 2 blue LED on it will lit on.. here only one. even i tested the led and its fine.
      voltage on T-CON F1 from both side for me little high 12.55V ( could be indicated open / not complete operation on the T-CON.
      disconnect...
      04-23-2022, 05:02 PM
    • valvashon
      Insignia NS-LCD19-09 no standby LED; (new problem)
      by valvashon
      Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
      Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
      Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
      08-30-2023, 10:41 AM
    • tbsmith
      Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
      by tbsmith
      There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
      08-11-2025, 06:15 PM
