I was hoping this was going to be yet another simple power supply
issue like the last two, but it was not to be.
This time I used my oscilloscope to check the +24DCV and +5V,
to make sure they were stable, and they were.
The backlight was not working, even with the +24V there, but the
"BLON" (back light on) pin was at zero volts, so I jumpered
this pin to +5V using a 1k ohm resistor, and the lamps turned
on, working just fine, but the screen was a blank black screen,
because the main board wasn't displaying anything, no menu
or anything.
So it's pretty clear it's a main board issue:
"BLON" (back light on) pin is on the white connector on the right most, bottom
corner. I measured some of the resistors in the lower right corner at +3.3V, but there
were also some areas that measured a weird +16V. WTF??????
But most of the advice here is for SMPS, inverters,
fuses, and caps, but not so much advice for fixing
main boards, so I ain't holding my breath, but just
in case someone knows something about this board,
I'm naturally all ears......
But it looks like it's Ebay time, yet again!
or anything.
