Panasonic TH42PD60U
  • Tibbs
    • Dec 2012
    • 6
    Panasonic TH42PD60U
    10 Flash code when on button pushed. Managed to trace my problem to the TNPA3794 board. Visual inspection showed some hot spots and cold solder joints around D461. Resolder didn't help. Any advice on where to go from here? Possible onboard resistance measurements?
    Re: Panasonic TH42PD60U
    Test the resistance between Vs and GND. You have a SC or SS short.
    • R8erfan
      • Feb 2020
      Im having the same issue can you elaborate for a novice.
      • R8erfan
        • Feb 2020
        Did you resolve your issue?
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • Jane
          What is the lowest acceptable resistance on a coil without considering a short on PCB
          by Jane
          I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
          Thank you.
          02-27-2024, 01:42 PM
