IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
  • Leo77
    replied
    Re: IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
    Originally posted by budm
    Any good clear pictures of the top and bottom side of YOUR board?
    Originally posted by Leo77
    Hope these are clear enough
    Here's another
  • Leo77
    replied
    replied
    Hi need help with my delta board power supply. Symptoms are no power no standby lights. I found IC blown apar R 7914 open and changed diodes. Still no power. I have 120vac in and some DC going out not sure where to look out. What watt Is the 2.2 ohm resistor suppose to be. Any help will be greatly appreciated.
  • Leo77
    replied
  • steinless
    replied
    Zener Showed about 700
    2k came from 264 for some reason
    Thanks!
    replied
    Great, so the Zener did show 2K when you test with Ohm meter?
    7.5V should be OK or 12V 1/2W will be more than enough, as you can see in the application notes, there is no clamping Zener diode being used.
    "Can i do without the zener? if it can light up, i suppose it is more for circuit protection and at most it will fry the opto or 264 should another surge occur?" Yes you can,that is correct.
  • steinless
    replied
    Not TL431, you can leave out the Zener for now to find out if the circuit will startup or not.
    IT...LIT UP..... THANKS BUDM!!!!
    Have found these specifications for the zener though. will a general 15 V zener diode do?
    THANKS!!!!!!
    replied
  • steinless
    replied
    So when you removed the jumper, pin 4 shows high resistance, so the low resistance is on another end of the jumper which is connected to the opto, zener,amd I cannot see what else, you need to find out.
    How abut those resistors that are connected to pin 4? They are not installed from the factory?
    As you can see the intenal of the IC, pin 4 EN/UV is connected to MOSFETs inside which should not have 2K reading.
    Yups they are not installed from factory.
    It seems to be coming from the zener. It works but the low resistance is from there. what specifications do you recommend? the data sheet only sorts of write a TL431. a normal 1N4728 will do?
    replied
  • steinless
    replied
    Nope i think i still got the 2k without the opto. Do not have the board now. Will try later. I believe it came from the TNY264pn?
    And nope dont think anyone worked on this as well before. When i saw the 4 empty slots where the resistors where, i was quite purplexed as well.
    replied
    The Zener can be left out for testing for now. So with the opto removed, you do not get 2K reading, is that correct?
    Did some one work on this board before?
    The other board has resistors which are connected in series to provide voltage to pin 4 (you can see that in the IC spec sheet), they are R7913, 7916, 7917, 7920.
  • steinless
    replied
    Hey Budm
    I put the a new opto, but it seems it just reverts to as if the old opto was there. Unless of course the new opto doesnt work, I tried to test it, but i am not sure how to do it. One way resistance 6M, the other side is open.
    Resistance across S and EUNV goes back to about 2k ohms again.
    HMmm...
    Should i try changing the zener diode?
    Would it be easy to just bypass the whole standby thing? i am happy to live without it.
    Where should the 1v come from anyway? I tried to trace it. It ends at the zener/ opto area unless i go to the other areas..
    C7918 and C7915 comes to 2V
    Thanks alot mate...this is a very grueling exercise..
  • steinless
    replied
    So did you put the jumper back in place then measure the resistance with one leg of the diode lifted off the board to see if you still get 2K reading on pin 4 and S (GND)? We are trying to find out where that 2K reading is coming from.
    Ahhh... ok i get it. thanks thanks. Yes, i did take out the diode
    I took out the opto. so i tested the opto by itself. not working now it seems. i guess it was the TNY264 which i was testing.
    The 2Mohms and 12 Mohms were coming from the TNY264.
    Ill get the opto changed and try testing again
    Thanks!
    replied
  • steinless
    replied
    OK, we need to trace where the other end of that jumper is connected to. I need better pictures of the STBY section so I can easily see the traces, I believe it is connected to the Cathode of Zener diode D7905? and the opto-isolator (IC7905?). I believe either the Zener or the Opto is damaged when the IC went out. You can put the jumper back in place and lift one leg of the D7905 to see if the resistance will go up.
    Here you are. Yes D7905, i think it connects to IC7906 though.
    How do i test the opto? I dont have a power source to test the output.
    What i have though after taking out one leg of D7905, forward resistance is 2.6m, backward resistance if i reverse the polarity is 12m.
    tested D7905 seems working.
    other side of opto resistance is about 1k whichever polarity. If i test the opto as two diodes on each side they seem to be working. Not shorted on the input and output sides.
    replied
  • steinless
    replied
    BTW: I dont see a J7080, Closest to pin 4 is J7026? They are the same? yes, per you board, lift one end off the board.
    2.6 M ohms
  • steinless
    replied
    Yea, its a variation board i think.. mine is DPS-226AP-1 RDENCA340WJQZ
    From what i see in the other board picture? I assume you are just trying to isolate pin4? I will just go ahead with J7026.
    replied
