IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
I was able to open the PDF, but it was one page without specs of any of the parts in the diagram. I ordered both some 1/2W and 1/3W resistors. I'm not sure what to install in the board. I did find some 1/4W resistors on another website that I can order, just not sure if I need to.Comment
Hi, I have Sharp LC-42A66M and having intermittent power off problem. TV will shut off of a few seconds[no green/red light at front LED] and it came back. It happens once/twice a day. And, sometimes no problem for a few days.
I though it was bad cap and opened up and checked the power supply board.
But, there was no bloated cap on board.
Power supply board is DPS-226AP-1 (RDENCA340WJQZ)
Is it possible that TNY264AP is having intermittent issue?
Should I just replace it?
Thanks in advance.
I just wanted to say thanks for this thread, it got by DPS-286ap up and running again. I ended up replacing R7914 (failed open), R7918 (seemingly OK at 2.2ohm), IC7905, D7908, and D7905 (showing around 400ohm).Comment
Did you replace all the components or only the R7914? when i replace the R7914 always blows.Comment
It blew open circuit because you have shorted component on the output side of the R7914, check the resistance of the STBY SMPS IC7905 PIN 8 and Primary circuit GND for very low resistance.Never stop learning
Thanks!, but i no have a lot of skills on electronics, only the basic, can you show me where to test, and what to test?Comment
I already indicated in my answer.
Correction, is your IC TNY264? If it is, then it will pin 6 and GND.Attached FilesLast edited by budm; 09-14-2016, 07:21 PM.Never stop learning
Sorry, typo, it is pin 5 the Drain pin.Never stop learning
Hi Budm,
I have same issue, I find R7914 open ans I change it using resistor 2.2ohm 1W, when I on the power the new resistor directly blow,
Please adviceComment
Check pin 5 and GND pin of that SMPS IC as shown in post 71.Never stop learning
Dear budm,
Thank you so much for your reply and explanation,
I follow your instructions and I find IC TNY264 is damaged.
Will replace it with new one + R7914 and will update the results.
I check the D & R at standby power supply and all are ok.
Thank you budm.Comment
https://www.youtube.com/edit?o=U&video_id=jkJ5t00p90w
I checked the voltage in the clips in the YouTube upload I see. Every power point is in the printed circuit board. I removed the circuit board to check. Any member Can you suggest me to check if MB is good or not? Can I make MB work on my own?Comment
Just a heads-up that I'm lurking on this thread today. My Sharp Aquos powers off about every 2-3 minutes while in use. I have never attempted circuit board repair before so this is all new to me, but I'll post back with my findings. Hopefully it'll be helpful to others.
This afternoon I replaced R7918 but it didn't seem to do the trick. I'll be replacing R7914 next, since it seems like some folks have had luck with that.Last edited by kreeger; 05-25-2017, 05:27 PM.Comment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
