LG 50PQ6000 unstable 5v standby
    Re: LG 50PQ6000 unstable 5v standby
    That is fine, the PFC is switching off.
    • Baileybum1234
      • Sep 2012
      • 245
      Wow something works!
      Repaired: LG50PQ6000
      • Baileybum1234
        • Sep 2012
        • 245
        so why does it go nuts when I plug in the Y-sus and Z-sus boards?
          Perhaps the low 3.5V is causing problems with the rest of the logic.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            I don't think it is fine for it to be jumping all over the place when its in the TV, right?
            Muh-soggy-knee
            • Baileybum1234
              • Sep 2012
              • 245
              Another area I have a question mark over:
              ACDETECT with the board dissconnected from the TV jumps about with the clicking but never over 1v?
              maybe a clue to you guys?
              When I connect the board to the TV it gets the 3.5VDC somehow.
              • Baileybum1234
                • Sep 2012
                • 245
                I would expect it to be stable when working.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Me too.
                  What does the manual say about the ACDETECT? I.E., does it say that when AC is detected, the ACDETECT pin is high? low? what about if there is a power failure (AC power drops out, due to power outage, or being unplugged)?
                  Muh-soggy-knee
                  • Baileybum1234
                    • Sep 2012
                    • 245
                    AC Detect is generated on the SMPS, by rectifying a small sample of the
                    A/C Line at D102 and associated circuitry and routed to the Controller (IC701) where it outputs at pin 15 and sent to P813
                    pin 18 to the Main Board where it is sensed and monitored by the Main Microprocessor (IC1). The AC Detin this set works differently than most. If AC Det is missing the Microprocessor will turn off the television in about 10 seconds after turn on.
                    This will happen each time turn on is attempted.
                    • Baileybum1234
                      • Sep 2012
                      • 245
                      PIN:18
                      LABEL:AC Det
                      STBY:5V
                      RUN:5V
                      DIODE MODE:Open
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        That would mean that when there is AC, the ACDETECT would be high, as it is when the mainboard is connected in your case.
                        I don't know why it would be low with no mainboard, but I think some of the filter caps next to the small heatsink on the bottom right could be dried up inside.
                        Muh-soggy-knee
                        • Baileybum1234
                          • Sep 2012
                          • 245
                          ok the 3 capasitors? I will remove and test tomorrow. It looks like there is another rectifier, an IC and another thing with 3 legs fitted to the heat sink.
                          So it this like another 5v supply circuit and those capasitors are filtering out noise?
                          • Baileybum1234
                            • Sep 2012
                            • 245
                            Manual said its the STBY 5V, 5V, 12V Source
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              They are saying that the 5v standby is derived from 12v [standby]?
                              I think there could definitely be an issue with the capacitors.
                              Can you take a close up of that side of the board? So we can see the ICs/rectifiers part numbers?
                              Muh-soggy-knee
                              • Baileybum1234
                                • Sep 2012
                                • 245
                                Hope these are good enough.
                                • Baileybum1234
                                  • Sep 2012
                                  • 245
                                  Do you need the back also?
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Sure, wouldn't hurt!
                                    Muh-soggy-knee
                                    • Baileybum1234
                                      • Sep 2012
                                      • 245
                                      MANUAL:
                                      AC Voltage is supplied to the SMPS Board at Connector SC101 from the AC Input assembly. Standby 5V is developed from
                                      160V source supply (which during run measures 380V measured fromthe primary fuse F302).
                                      This supply is also used to generate all other voltages on the SMPS.
                                      The STBY5V (standby) is B+ for the Controller (IC701) on the SMPS and output at P813 pins 11 and 23 then sent to the
                                      Main board for Microprocessor (IC1) operation.
                                        If possible. I suspect the 5V MAIN is derived off here...
                                        If the 12V is also low by about the same amount (30%), then the suspect would be the primary side, controller IC, or TL431.
                                        I say TL431 because I now recall budm had a Samsung monitor with low rails, and it turned out to be the TL431 (voltage reference IC; for the feedback loop.)
                                        • Baileybum1234
                                          • Sep 2012
                                          • 245
                                          Rear of low voltage board area.
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • reessi
                                            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                            by reessi
                                            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                            Years ago it had some bulging caps...
                                            04-26-2021, 11:42 AM
