Vizio VX32L No picture, sound, or backlight
    Re: Vizio VX32L No picture, sound, or backlight
    Oh, I initially said the CPU survived it... But maybe it got damaged?
    Try on HDMI. If that works, the analogue part of the chip is shot -- no analogue sources will work.
    • johnboy1313
      • Nov 2012
      • 1959
      Well, I'm pretty sure my issue has something to do with a fried or damaged board. At the new regulator, I'm getting
      3.29
      1.65
      1.25
      I disconnected the adjust jumper from the board and get the same readings. With the jumper disconnected, I get the same results with the video input. Either I'm not getting the adjust pin connected to the board properly, or the board is fried.
      What do you guys think?
      • johnboy1313
        • Nov 2012
        • 1959
        I've only got one HDMI component and that won't work on the 720p units. AVG is analog isn't it?
          It should have 2.5V out put if the adjust pin is at 1.25V. It can due to it is not LDO regulator.
          • johnboy1313
            • Nov 2012
            • 1959
            Unfortunately, I don't know enough about regulators to know what you are saying.
              This is the way to figure out if the adjustable regulator is good or not:
              Notes: we are looking at the regulator with the Big tab up (the big tab is tied internally to the center pin).
              Adjustable regulator will have two resistors attached to it, one resistor (Rfb) is between pin1 and pin2, another resistor (Rg) is between pin1 and ground. Pin3 is an input pin.
              The voltage between the Adjust pin (left pin) and the center pin (Pin2, output) will always be 1.25V +/- 2% (this is the precision voltage reference), if it is not, it is bad.
              To figure out what the output voltage should be: measure the voltage between pin 1 and ground and add 1.25V to that number, that is the output voltage on pin 2 but you have to make sure you do have 1.25 between pin 1 and 2 as noted above
                ADJUST must be grounded. The regulator will then output 1.25V, but only if it is loaded sufficiently (it requires minimum of about 10mA to regulate.) To ensure it is loaded tie a 120 ohm resistor to ground.
                The output of all adjustable LDOs, as well as adjustable linear regulators, is Adjust+1.25V.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  So, with the adjust disconnected, I should have 1.25V at the out. And if I don't, the regulator is bad? If I do, the board, or at least the analog section of the board is shot?
                    No, not disconnected. It MUST be grounded.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Got it. Out of curiosity, why a 120 ohm resistor? Why not jut tie it to ground?
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Never mind, I see. Current draw?
                          120 ohms must go to ground from the output. This provides 1.25/120 = 10.4mA current draw, which is within the minimum specified.
                          So the INPUT goes to 3.3V or 5V, depending on which works.
                          The OUTPUT goes to the OUTPUT of the ex-regulator.
                          The ADJUST goes to GROUND.
                          A capacitor of 100nF minimum is required on the output. Input capacitance is also a good idea.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            I'm getting the 3.3 off the resistor that originally supplied it to the damaged regulator pad. The output is jumped back to the original spots too. I'm going to try to ground the adjust. I don't have a 120 ohm resistor, but I do have a 1k potentiometer adjusted down to 120 ohms. If it works, I'll pick up an actual resistor tomorrow.
                              You can use a lower value, but probably no lower than 10 ohm, as it would have to dissipate a lot of heat. (10 ohm = 0.144W; maximum for a 1/4W resistor is... 1/4W or 0.25W.)
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Well, the good news is the regulator works like it's supposed to. The bad news is there's still no video signal.
                                So going back to an earlier question. Does the 4a, 4b suffix on the main board part number make a difference?
                                  There should be existing resistors between the ADJ and OUT pin, and Adj and ground, unless those tiny resistors got damaged or removed during the installation of the replacement LDO.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Yeah, the adjust resistor must have gotten damaged.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Doesn't matter, the board sold.
                                      • ggil44
                                        Vizio M65-E0 No Picture, No Sound
                                        by ggil44
                                        Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                        09-03-2024, 08:30 PM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Ierwin
                                        by Ierwin
                                        05-13-2025, 03:31 PM
