Help needed on Philips 47 LCD Power Supply
  • MisterD
    • Oct 2012
    • 668
    Never mind!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Help needed on Philips 47 LCD Power Supply
    I know what is going on - ITS CALLED DOUBLE POSTING.
    Stop wasting our time.
    • MisterD
      • Oct 2012
      • 668
      I'm not wasting anybodies time, I'm trying to get some help, wasn't aware that this is considered double posting, I tried to delete this one but don't know how, sorry for offending anyone!!!! excuse me!!! I have not only got help from this site on other TV's I have fixed, I have also helped someone fix their 42" Vizio, relax, eat some more Turkey..Man this is unbelievable that someone would be this upset, If only that's all we had to worry about in life.
        It clutters the forum up, and if we do not post, that is because we cannot add anything at present.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          You are.
          You will
          You cant - but you could have edited it to Sorry posted in error
          Apology accepted
          Very commendable
          I am relaxed and I dont like turkey that much.
          • MisterD
            • Oct 2012
            • 668
            I can edit this Thread, but is there a way to just remove it? I tried but can't find a way to do it. Thanks!
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
