Vizio L32 No Backlight
  • kevinm34232
    • May 2012
    • 1884
    TV has normal standby and powers on, backlight flashes for a second then goes out. Can see video shining a flashlight on screen.
    Get approx 5v to BLON then goes down.
    Getting 24v to inverter VDD pins.
    F101-105 test good.
    T105 has a little residue by pin 1 where all others have a white dot.
    Inverter board part # is AUO 19.26006.095
    The specs for the 4005DXXXXXX(MS307T) transformers say:
    The secondary resistance is about 0.8 K between S1 and S2 (or S3 and S4). The primary resistance is about 0.5 ohm between P1 and P2 (P3 and P4).
    So I started checking with meter at 2k, not sure if I had the right pins for secondary but it's the only pins that gave me close to the specs:
    T101 - .892 .888
    T103- .896 .893
    T105- .886 .886
    T107- .889 .886
    T109- .855 .885
    T111- .879 .875
    T113- .909 .909
    T115- .873 .871
    If I did that correct I see some deviations in T109 and T113.
    Does it seem like an inverter board problem? I do not really have any way to test the lamps..
  • kevinm34232
    • May 2012
    • 1884
    Re: Vizio L32 No Backlight
    I was able to get the backlight to come on by bypassing the protection just to see what screen looks like. As you can see the OSD is fine but there is the black marks/shadows going down the screen. What is that??!
    Also as a side note, all of a sudden I noticed the power LED light went to green when plugging in, and unresponsive, instead of the normal yellow standby when plugging in. I figured something happened to the main board. Found an open 2A fuse on the main board on the 3.3v line, I musta hit something by mistake. Replaced it and back to where I was before..
      How did you bypass the protection?
      T109 does not look right with 855 Ohms reading.
      • kevinm34232
        • May 2012
        • 1884
        I had run across this article on another TV:
        http://www.bestelectronicarticles.co...ht-system.html
        I looked up my inverter IC datasheet and was similar, just had to ground pin 1.
        I figured it was worth a try to see what the backlights looked like or if screen was cracked..
        That black smear though I'm not sure what's going on with that..?
          OK, I have done that one before, was not sure if your board uses the OZXXXX IC or not.
          Thanks. That smear on the screen, was it there before? It is either contamination or some pressure was put on the screen to cause what you are seeing, not 100% sure.
          • kevinm34232
            • May 2012
            • 1884
            Well that's the thing I never saw the screen on before so not sure. I wasn't sure if that is a bulb issue or the panel. Wouldn't a bad bulb be a dark bar across the screen? Could whatever that is be causing the shutdown of the inverter? Those transformers are like $11 each on ebay, the whole board is around $50 which I don't want to do for this TV..
            I also left it on for few minutes and none of the transformers felt warmer than any others..
            • kevinm34232
              • May 2012
              • 1884
              Someone had posted somewhere a Youtube link of bypassing individual transformers on a Samsung for a bad CCFL lamp when there was a transformer for each lamp, I think that may work here does anyone have that link?
              • kevinm34232
                • May 2012
                • 1884
                I found the video I was looking for:
                http://www.youtube.com/watch?v=oE6K4...eature=related
                However this inverter doesn't have the same type of feedback circuit.
                Im trying to understand where the feedback signal is coming back from the lamps and where and how it's being interpreted on this board without a schematic.
                I've read some info about unplugging a suspect lamp and connecting a good feedback signal from another lamp to that circuit to determine if bad lamp or inverter I just want to see if it will work..
                  That is mura. Unrepairable usually. Maybe if a bulb has split and burnt, it has burnt the inside of the panel??
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • Yanleb
                    Vizio M70-D3 4K with dark spots backlight issue
                    by Yanleb
                    I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                    On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                    I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                    03-22-2022, 01:06 AM
                  • howardc64
                    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                    by howardc64
                    Problem
                    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                    Model & Board Pics
                    Conflicting Spec
                    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                    https://www.shopjimmy.com/vizio-gj-2k1...
                    10-10-2024, 01:16 PM
                  • x_orange90_x
                    by x_orange90_x
                    01-29-2025, 09:24 PM
