Samsung UN46C8000 LED tv not powering on
  • NDogg6
    • Feb 2013
    • 16
    Re: Samsung UN46C8000 LED tv not powering on
    Hey Bud, I have a question about my tv. It is the same tv. I swapped all the boards I could swap on my tv and now it turns on. All I get is a black screen now. When I power it on the red led indicator on the front does not shut off unless I push a button on the remote. Any ideas?
      On the power supply board LED backlights power supply, the connector that goes to the main board, you need to look for PS_ON pin, BL_ON pin on the power supply board and see what DC voltage you are getting when the TV is off and when the TV is ON.
      • tibimakai
        • Jan 2012
        • 3680
        https://www.badcaps.net/forum/showth...hlight=samsung
        It still works, it's in my living room.
          Ah TIBI, I am glad you remember this one, so it looks like he will need main board.
          • Rossputin
            • Sep 2013
            • 22
            OK, found the BL_ON and PS_ON. I have no way to turn TV on, though. Can only plug it in. When plugged in, no voltage on any pin in the connector to main board that includes the two pins just mentioned.
            Is there any way to try to turn on the TV without the little icon of a power button on the bottom glass that also functions as the switch? (Also, no response when pushing power button on remote.)
            So far, the only thing I find voltage in is the power cord!
            • Rossputin
              • Sep 2013
              • 22
              I took a look at the basic troubleshooting document, and frankly most of it is beyond me, unfortunately!
              • NDogg6
                • Feb 2013
                • 16
                I got power and the backlight to come on now. I just have no menu or display on my screen. I am wondering if there is some compatibility issue or something since I swapped all the boards on my tv. could it be that the part arent compatible with each other, for example when you put a new motherboard on a computer you cant you use the same hard drive without formatting it.
                  nDOG, so you can see the backlights and the screen has a slight glow to it but no pictures? If that is the case, check the SMD fuse on the T-CON board to see if you are getting 5 or 12vdc on both ends of the fuse with ref to the chassis ground.
                  • mutz
                    • Oct 2013
                    New to the board. I have a different issue but same TV. When powering on I have a purple screen, screen will come and go, sound will crackle. Then it will run normal, sometimes i will lose sound and picture for a brief second then back to normal.
                    • TdSnow95
                      • Nov 2016
                      Hello, I currently have a Samsung UN55B8000XF television that will not power on, only clicks. When I disconnect power to the main board the back lights do come on. I don't really want to buy a whole new main board, is there any suggestions you would have? Specially @Budm??
                        09-07-2024, 05:50 AM
                      • Egidio85
                        Samsung UE55F8000SZ Turns on and off immediately
                        by Egidio85
                        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                        This defect happens continuously, hearing the classic click of the relay every time.
                        Power supply board BN44-00636B
                        disconnecting the mains and lamps from the power board always causes the same problem.
                        Is it normal that without anything connected this power supply turns on and off cyclically?
                        any suggestions on what to check?
                        thanks in advance
                        03-11-2025, 12:45 PM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
