Sharp LC-32sb28ut Power Supply has Pulsing DC Voltages
Re: Sharp LC-32sb28ut Power Supply has Pulsing DC Voltages
Is the PS-ON on main board pulsing too?
I cannot think of any way it is not the power supply. Perhaps it is a common fault. Or even what it does in standby, for example to save power?!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The pin labeled "PS" on the power supply, which looks to
be the PS-ON, pulses from 3.1V to 0 V, again in time with
the blinking blue LED.
This PS-ON signal comes from the main board, right? So if it's pulsing,
perhaps that is why even the big main filter cap is pulsing as well,
because all it's doing is ramping ON and OFF.
Bummer, but perhaps I have two good power supplies I can sell....Comment
That makes sense.
If it is anything like the cheap made in China TVs I have serviced, they will begin the power up, "crash" due to a fault, wait a few seconds then restart. Hence the pulsating DC, the entire PSU is being switched on and off. This isn't a real Sharp, so they haven't designed it well -- a good Sharp would go into lock out, blink an error code and everything would hopefully be easy to locate.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Man, I feel bad not asking you to check the PS_ON signal!Never stop learning
Yeah, it's amazing how you can veer off into the wrong
path completely!!
BUMMER!! Oh well, at least I can sell two good power supplies now!
And the inverter board is probably ok too, but I've had bad experiences
with Ebay buyers lately, so maybe I'll hold off......haha!Comment
Yep, I missed this one right here" Then I checked the +5V when I first plug it in (Red LED standby
mode), and it was at +4.1V" The main board is drawing too much current form the standby power supply (or the standby is not steady since it is not controlled by the PS_ON). It is not easy sometime when you do not have the board in front of you.Never stop learning
Sometimes it's hard even with the board in front of you......Yep, I missed this one right here" Then I checked the +5V when I first plug it in (Red LED standby
by Goldwing1973I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
But, whats is not normal is the pulsing of resistor...-
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
by bridges_4uI have an 820-3435-B bought in by a customer that is not turning on. I have PP3v42 @ 3.292V, PPBUS_G3H @ 8.48V and PP3V3_S5 @ 3.298V. I do have amber light on the charger. All the other voltages are pulsing including PM_SLP_S4 as well. Any have any pointers where to start looking because, it can be caused by a horde of issues. Schematics attached.
by speggio91Hello everyone!
I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
The pulses are present in the CPU Vcore rails on L7320 and L7310.... - Loading...
