Ok, when plugged in, there is the normal red LED
on the front, but when you try to turn it on, the Blue
LED comes on, but starts blinking at about a 1Hz rate.
And then, you cannot turn the unit back to the red LED,
as it becomes stuck in the blinking Blue condition, and there
is totally black screen, and no sound. Nothing.
So I checked the voltages, and even with the inverter
disconnected, ALL the DC voltages will pulse IN SYNCH with
the Blue LED, at the 1Hz rate. The +24V will dip to about
+20V, and then back to +24V. The +5V will dip to about
+4.1V. The +12V will dip to about +9V or so.
Then I checked the +5V when I first plug it in (Red LED standby
mode), and it was at +4.1V. So it only goes up to +5V when
you attempt to turn it on, but it doesn't stay there solidly like it should.
This picture is exactly like mine:
http://www.google.com/imgres?um=1&hl...9,r:1,s:0,i:77
I used my Russian ESP cap meter, and all the electrolytics appear
normal. I'm about to check the diodes, but if someone has
a suggestion, I'm all ears......
