Low Capacitance Meter Recommendation
  • tieny
    • Feb 2012
    • 478
    Hey guys I was wondering what are some good capacitance meters that can measure in the low range (ex. pf or lower) Specifically used to measure smd or ceramic disk capacitors, etc.
    I already have the Altas ESR70 ESR Meter which does a good job for normal capacitance and ESR reading but it doesn't work for lower range readings.
    Any suggestions? I'm looking for a generally cheap meter that just gets by enough to work.
    Re: Low Capacitance Meter Recommendation
    Most DMMs have capacitance ranges that work down to 1 nF, with 0.001 nF (1 pF) resolution on my BK 2709B.
    • Dannyx
      Hilti PD30 Laser Range meter Error 276
      by Dannyx
      Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
      So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
      07-30-2023, 05:05 AM
      12-31-2023, 06:04 AM
    • jorpec
      by jorpec
      Hi
      Thnaks
      01-23-2023, 10:37 AM
      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
      12-14-2023, 07:45 PM
      Sacon FZ revival experiment
      by momaka
      So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
      https://www.badcaps.net/forum/showpo...&postcount=548
      … and here:
      https://www.badcaps.net/forum/showpo...&postcount=585
      … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
      The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
      01-26-2022, 08:43 PM
