Vizio M470NV Backlight
  • Primez
    • Nov 2012
    • 5
    Alright, so I just picked up a Vizio M470NV TV sitting outside that someone left behind thinking "All hope is lost". I however am much more optimistic and figured it was something simple such as maybe a fuse.
    The problem I am having is with the backlighting.
    When turning the lights off I can see the picture while shining a light on to the screen. I also have no issues with sound. It seems that the only issue is with the backlights.
    What I'm asking for is some assistance in pointing me into the right direction on where I can find the fuse for the LED power supply to find out of that's the issue or if I need to search deeper into the strips themselves? I'm hoping someone in the community has had experience with this TV.
    -Thanks!
  • XmouseX
    • Aug 2011
    • 158
    • US
    Re: Vizio M470NV Backlight
    We are trying to figure the same thing out on my Vizio LED edge. I will let you know when we have a conclusion
    • drpj23
      • May 2012
      • 528
      I've just messed with a M470.
      The power supply should connect to a smaller LED driver board. There may be a smd fuse on that.
      Also check the voltages coming from the psu to driver board and I believe there was also a ribbon from the main to the driver board; you can check that as well.
      If for some reason you conclude its the actual strips (rare in my opinion), I do have those. (Though mine wasn't a NV).
      • Primez
        • Nov 2012
        • 5
        Edit - Typo'd
          @XmouseX, I wonder if his board use that 540N regulator IC, if it does, then we ask him to take the voltage reading at the output pin for us!
          Never mind, his board is way different than yours.
          • Cosmo66
            • Nov 2012
            • 87
            I had a Vizio 47 inch lcd with the same symptoms. There were 2 bad caps and one blown small surface mount fuse on the inverter board
              You can disconnect the wires that go the the LED String assembly which are connected to the two blue connectors, per printed on the circuit board, it should have 145Vdc output, be careful not to slip the probe!
              http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
              There are white connectors on the bottom row, look for BL_ON PIN and see if it has >3VDC on it, that pin is used for turning backlights ON/OFF, ON = >3vdc.
              • Primez
                • Nov 2012
                • 5
                @budm - On the blue connectors, my readings across the pins are:
                VLED: 114v
                4-1: 12v
                4-2: 10v
                4-3: 12v
                The voltages are the same for the other 3 "groups"
                As far as the white connectors, they all have the proper voltages as well as the BL_ON pin is >3VDC
                  BL_ON pin is >3VDC is good and it is turning on the power supply for the LED OK. So connected the LEDs cables back in and see if you will still have the 114V.
                  • Primez
                    • Nov 2012
                    • 5
                    Sorry, that was with the cables connected.
                      4-1: 12v
                      4-2: 10v
                      4-3: 12v
                      I will need to figure out what these voltage readings mean.
                      • Primez
                        • Nov 2012
                        • 5
                        I have a feeling it is something with the LED backlights themselves and not necessarily a power issue. I don't think that voltage drop is the problem because it's pretty consistent throughout the plugs.
                          4-1: 12v
                          4-2: 10v
                          4-3: 12v
                          The example of the voltage readings are done at the LED return connectors, you do have the VLED feeding the LED strings OK, the voltage on the return lines just do not look right. Need to see how they do the current control of the LED strings.
                          Can you look and see how those 4-1,4-2, etc are connected?
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Attila Jamilov
                            Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
                            by Attila Jamilov
                            I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
                            Also from further search...
                            04-20-2025, 10:02 PM
                          • Yanleb
                            Vizio M70-D3 4K with dark spots backlight issue
                            by Yanleb
                            I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                            On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                            I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                            03-22-2022, 01:06 AM
                          • howardc64
                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                            by howardc64
                            Problem
                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                            Model & Board Pics
                            Conflicting Spec
                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                            https://www.shopjimmy.com/vizio-gj-2k1...
                            10-10-2024, 01:16 PM
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
