Samsung PPM50M7HB No Picture with Black Screen
  • Virden1
    • Nov 2012
    I have a 50 Samsung plasma monitor that has no picture. The power light flashes a slow blinking green light then goes solid green when powering on. I took the back off of the TV and found 2 bad capacitors on the Y - sustain board. I replaced the bad capacitors with new ones that were the same specs. I powered the set back up, green light stays solid green, and still have the same issue. I double checked all the boards just to make sure I didn't miss a bad capacitor and found nothing. All fuses were good too. I did notice that there is a little LED on the Y-sustain board glowing solid green, so I'm assuming that the board is good and there is something else wrong in the TV? Any suggestions would be great!
    Thanks,
    Steve
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • String2016
    samsung np300e green screen
    by String2016
    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
    07-26-2025, 04:00 AM
  • arbitarytwist
    Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
    by arbitarytwist
    Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
    Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
    03-01-2025, 01:16 PM
  • kokos
    LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
    by kokos
    Hi ! to all fellows out there!
    I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
    I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
    The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
    I tried connected the lan and I can seee TV via local lan (as a device I...
    02-26-2024, 10:48 AM
  • Nopy
    Sony KDL-55EX500 solid green screen
    by Nopy
    I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
    My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green...
    03-08-2022, 07:48 PM
