Panasonic plasma TC-P42S30 transistor on SN board blows 1 second after power on.
  • mattpd
    • Oct 2012
    • 302
    Here is the service manual I found:
    If you look on page "S-36" you will see the problem board. When I first got the TV, It would not power on and gave a 14 blink code. I see that 14 blinks is not listed in the service manual but I tripled checked the count and it was 14. There were 4 blown transistors that I replaced from a donor board. These were Q401, Q402 and two others that I don't remember off hand.
    After this repair attempt when I turn on the TV I get sound and picture for 1 second and then the TV shuts down with a 6 blink code. I pulled the board and checked all the components that I replaced, and they were still good but transistor Q441 was shorted. I replaced Q441 and again it comes on for 1 second and then 6 blinks. I only have one more of these transistors left so I need to find why it is shorting before trying again. Any ideas?
    And on another note, why is it that in the service manual if you look on page "S-50" Q441 is not listed. In fact the lowest part number is Q1101 and it goes higher from there... Am I missing something?
    Re: Panasonic plasma TC-P42S30 transistor on SN board blows 1 second after power on.
    The part numbers on Panasonic schematics start with a prefix, e.g. "16", "21" then the part number. So Q411 might be Q16411, or whatever the prefix is for the SN. Have you checked if you are getting good Vs (around 200V)? Any defect with the picture when it's working for that one second? Will set work with transistor missing?
    • mattpd
      • Oct 2012
      • 302
      Thanks for the quick reply, and thanks for the tip.
      It did see some horizontal lines when it powered on the first time, but I am almost certain it was because the ribbon cables were not seated completely. I will try the board with the transistor removed tomorrow. As far as testing Vs, can you advise the proper procedure?
        There is a test point on the power supply. You can check across the Vsus points, near "Discharge". You should get around 200V, but the exact figure will be written on the panel sticker.
        • mattpd
          • Oct 2012
          • 302
          Ok, I will try both things tomorrow.
          • mattpd
            • Oct 2012
            • 302
            So, I hooked the board up with the transistor missing. I think I heard a pop when I powered on the TV. The TV came on with no blink codes, but there was also no picture or sound. Unfortunately there is now a short to ground somewhere... Any tips on locating the part that has the short?
              You would have to test every transistor. No quick way that I'm aware of.
              Are you sure the part is a transisor? For example you aren't replacing a diode? If it is a transistor, it's definitely the right type? (IGBT and MOSFET are not typically interchangeable.)
              • mattpd
                • Oct 2012
                • 302
                The replacement parts came off an identical board. I think 4 were MOSFET and one was some other kind of transistor. The only way I know this was by hooking them to a component analyzer. I cant find any information on these parts, i guess because they are manufactured by Panasonic.
                After some more investigation I have noticed that there is NO picture for the 1 second the TV comes on, only sound. Also, I found the short. It was in all 4 of the MOSFET I replaced. So I think there are 5 different transistors that blow as soon as the TV is powered on. Q401, Q402, Q421, Q422, and Q441.
                  I would suspect the SN buffer chips unfortunately they're not on a separate buffer so you're SOL if you want to replace them unless you like soldering 128 pin QFPs.
                  • mattpd
                    • Oct 2012
                    • 302
                    Is that one of the 12 Panasonic chips that are glued to the board? Just out of curiosity is there a way to tell which one is bad? I do have some chip-quick and a rework station, so its not out of the question to swap one, although that glue on the pins makes me think twice. It's all for fun/learning now anyway as I have already ordered a new board to get the TV working.
                      Yeah, it's those ones. If you can isolate the sus waveform to them, you can feed them 12V DC and see which gets hot... but as they're on the board, it could be tricky.
                      This thread has someone trying it with an LG: https://www.badcaps.net/forum/showthread.php?t=23438
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                        11-20-2024, 08:52 PM
                      • Dannyx
                        Panasonic SU-HTB18 dead power supply (unidentified transistor)
                        by Dannyx
                        Good day folks. I had a look at this soundbar from Panasonic today and it seemed like an easy enough fix, but then I got stuck.
                        Have a look at that fried primary. I reckon the transistor popped and took out the current sense resistors with it before the fuse could open to cut the power. I thought I'd have a hard time figuring out what values those are, as it usually happens when SMD resistors go up in smoke, but thankfully I was able to clean them enough to read 1r60 on there, which is 1.6ohms, so that was sorted - we need 8 of those.
                        On to the transistor: it's one...
                        01-23-2021, 10:33 AM
                      • AquaMan Ua
                        by AquaMan Ua
                        05-17-2025, 09:40 AM
                      • magneh
                        Behringer Eurolive B205D repair - help identifying transistor
                        by magneh
                        Hello
                        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                        Still, I need to replace this transistor....
                        06-18-2025, 02:34 AM
