Proview rx-276 2600
+ More Options
Posts
  • Snype32
    • Jun 2011
    • 76
    Proview rx-276 2600
    I have recently acquired a proview rx-276 from our local dump. It powers on and the screen flashes for a second, and goes out. Green led stays on. Caps all appear to be good, but I replaced the caps indicated here: http://blog.coppelltvrepair.com/2011...-power-on.html
    Power supply seems to be putting out 12v contunious and 24v switched on a different connector. Is this right? I thought it was supposed to put out 24 on both connectors. Any help would be greatly appreciated. The power supply in question seems to be exactly the same as the one in this thread: https://www.badcaps.net/forum/showthread.php?t=23501
  • smason
    • 1652
    Re: Proview rx-276 2600
    Check the BL_On signal on the inverter board. If it's on, and the backlights shut off, it's likely the inverter sensing a bad ccfl, or a problem on the inverter board like a bad transformer.
    • Snype32
      • Jun 2011
      • 76
      Thanks for the reply... What am I looking for on Bl_On?
      Thanks!
        >3VDC = Backlights on, <1v = off
        • Snype32
          • Jun 2011
          • 76
          Ok so I finally got around to checking what I think is BL_on. I could not find any label indicating it, but there is a pair (yellow and white) that is the only wires seperate from the power supply. I get over 4 volts across the pair, so that means the backlight should be on? The lights do flash for a second, then go out. I am getting 24 volts to the inverter across all of the red and blacks. It seems like it should be working. Any ideas?
          Thanks!
            Do the yellow/white go to the inverter? You should test from yellow to chassis, and white to chassis.
            One wire will be backlight on/off, the other will be brightness.
            • Snype32
              • Jun 2011
              • 76
              Thanks for the quick reply... Yes the yellow and white both come from the inverter. They are both in a connector. At the inverter, I get 4.8 on the yellow, .05 on white.
              How can I tell which one is brightness vs bl_on?
              Thanks for all the help so far!
              This may be a stupid question, but is there any way it could be just the brightness turned all the way down? Can I apply a couple volts to the white and get the backlight on enought to see the menu? That would be too easy.
                Unfortunately, you can't easily tell which is brightness and which is on/off. Do they change state when you press the power button? I know some TVs leave the brightness control fixed and then vary the on/off signal.
                If you have two AA batteries and a battery holder, it is quite easy to control the on/off signal.
                • Snype32
                  • Jun 2011
                  • 76
                  The yellow is 0 on off and 4.8 when on.
                  The white is 1.2 when off and 0 when on.
                    OK it looks like yellow is on/off, and white is inverted brightness (0V = max brightness.) I have seen an inverted brightness signal before.
                    Can you post an image of your inverter board? The fault is most likely on there.
                    • Snype32
                      • Jun 2011
                      • 76
                      Here you go:
                        This is a Darfon inverter; the transformers are very common failures.
                        How to test:
                        1. Unplug the TV.
                        2. Test resistance between red marks using the 20k ohm range. Note this down.
                        3. Test resistance between blue marks using the 20k ohm range. Note this down.
                        4. Test each set of two transformers like this; note the red and blue alternate. For the last transformer, test it as just the first transformer of the group.
                        5. Report the readings in this thread.
                        • Snype32
                          • Jun 2011
                          • 76
                          Here are the results. The ones that are open did show a number for a second, then went open. I'm not sure if it's my meter or what.
                          Thanks for the help
                            Something's not right here. Did you use the 20k ohm range? All but one winding should measure virtually the same. The failed winding is the one which significantly differs. Also make sure the value on your meter settles before reading it off.
                            • Snype32
                              • Jun 2011
                              • 76
                              I did let it settle. Maybe I am not measuring the right leads?
                                Can you show which range your meter was set on by taking a photo of it in that setting.
                                Also touch the probes, does the meter read nearly or exactly zero?
                                • Snype32
                                  • Jun 2011
                                  • 76
                                  When I tested them acorrding to this site:
                                  http://www.lcdparts.net/Transformer3D.aspx
                                  All show .95 except 1 that is open
                                  • Snype32
                                    • Jun 2011
                                    • 76
                                    Here you go...
                                    and yes it shows .0.. when leads are together
                                      Hmm maybe I'm not understanding how this board works, it happens. Try testing across red and blue for each to see if the results are more consistent. So red and then opposite blue, for the top and then for the bottom, for each transformer.
                                      • Snype32
                                        • Jun 2011
                                        • 76
                                        so on these leads? If so, all except 1 are .95. One of them is open
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                          ACER Veriton 6610G Veriton M i7-2600 Specification for Upgrade or Repair
                                          This specification for the ACER Veriton 6610G can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton 6610G boardview and Veriton 6610G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                          09-12-2024, 03:36 PM
                                          ACER Veriton M6610G Veriton M i7-2600 Specification for Upgrade or Repair
                                          This specification for the ACER Veriton M6610G can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton M6610G boardview and Veriton M6610G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
