LCD Burn In
  • ChaseB1989
    • Oct 2012
    • 11
    • U.S
    LCD Burn In
    I have a Polaroid LCD TV that has a burn in mark on it . What is the best way to get rid of or reduce the Burn in?
    Re: LCD Burn In
    It is not burn in. Unfortunately Polaroid used very poor quality CHUNGWHA, CHI-MEI or sometimes AUO LCD screens in these TVs which have mura build up over years. The problem is unrepairable, though reducing the brightness and loosening the case screws can sometimes reduce the effect.
    • ChaseB1989
      • Oct 2012
      • 11
      • U.S
      Re: LCD Burn In
      Thanks for the quick reply.That's too bad, now the value of the TV is permanently reduced.
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • howardc64
        Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
        by howardc64
        Eventually discovered a burn mark near lower corner of LCD. Here is a summary
        • Backlight on, no image
        • Disconnect right buffer board (view from front), left side display comes on
        • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
        • Buffer board is pretty simple
        Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
        07-11-2025, 04:04 PM
      • Seville
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
        by Seville
        Hello all!
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
        I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
        10-10-2022, 07:31 AM
      • dumbdd
        Sony VA panel burn in
        by dumbdd
        I have a Sony 75x940e that I just fixed with the help of the forum (bad emmc). For the last couple of months I was noticing some burn in of the android home icons on dark backgrounds (photo is attached). I always thought VA panels were immune to burn ins. Is there anything I can do to fix it? Could it be because of a failing component other than the panel itself?...
        07-19-2023, 09:23 PM
      • lowpost99@gmail.com
        Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
        by lowpost99@gmail.com
        I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
        09-03-2024, 02:57 PM
