Troubleshooting Vizio VA370M with bad main board.
  • HiroP713
    • Oct 2012
    • 3
    I have a Vizio VA370M which will not power on. When I hit the power button the vizio logo changes from amber to white but nothing else happens. I've already diagnosed this as a bad main board. My boards model number is CBPF9D1KZ5. I tried a CBPF9D1KZ7 board in it and the lcd powered on but had interlacing issues. I had read that some other vizios had issues with bad regultors so I've measured the two regulators I can find on the front of the board and attached a picture. There is one other voltage regulator on the back of the board which I have not checked yet. Any help is appreciated.
    The top regulator has the following markings: L161 903T63
    I was able to find a datasheet for it and it seems to be working properly.
    The bottom regulator has the following markings: 17809 96 59
    I was unable to verify if it is functioning properly.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Troubleshooting Vizio VA370M with bad main board.
    The above is a 7800 series regulator. More specifically a 7809 with 9 designating the output voltage.
    --- begin sig file ---
    --- end sig file ---
      "When I hit the power button the vizio logo changes from amber to white but nothing else happens" Is this the symptom of the original board?
      • HiroP713
        • Oct 2012
        • 3
        Yes it is.
        • smuddge
          • Feb 2012
          • 96
          I know this is an old thread but if anyone else has this problem it is the processor on the mainboard that has cold solder joints. just did a reflow on one here for the heck of it. was just going to throw it out if it didn't work. voila working.
          yay. saved it from the landfill for now anyways.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Good job!!!
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
            • afdreher
              Vizio M60-C3 won't turn on. Is it the main board?
              by afdreher
              Hi, I've been stalking the site trying to diagnose the problem with my Vizio M60-C3. When turned on, the screen remains black and there is no audio. There is nothing displayed on the screen using the flashlight test, but the status light does illuminate and the optical audio out port does illuminate. The symptoms are almost identical to https://www.badcaps.net/forum/showthread.php?t=51443.
              On the power supply board (60CAP090), with the TV off, everything reads ~0V except for the two +12V rails (pins 8 & 9 on the connector the main board (CN201)), which read 12.57V, and the AC-DET...
              05-22-2020, 02:06 PM
