Panasonic TC-P50G15 6 Blinks
  • argonrepublic
    • Oct 2012
    • 9
    *I have 6 Blinks on LED
    What is the next best step?
  • drpj23
    • May 2012
    • 528
    Re: Panasonic TC-P50G15 6 Blinks
    Make sure the ribbons/connectors are seated properly between the SC, A and C boards.
    Can you check/report the voltage on pin 21 on SC20 before shutdown occurs?
    Lastly, do you have a C10 connector on the C1 board?
      I had a P50G10B with 6 blink code, I never solved it, though I suspect the SC was the fault.
      • drpj23
        • May 2012
        • 528
        Ya, that's probably what it is going to be.
        • Mt.Man
          • Jun 2012
          • 53
          6 blink is a SC, SU, or SD error. If your SU and SD boards are not shorted, then most likely a bad SC board.
            In rare cases, a failed SS can cause the SC to throw an error, too.
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
              11-20-2024, 08:52 PM
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • CrewmanRedShirt
              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
              by CrewmanRedShirt
              Hello all,
              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
              07-13-2024, 11:02 AM
            • nobbnobb1
              Panasonic TC-P50U50 Powers Off - 8 blinks
              by nobbnobb1
              I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
              2x DG302 (Q16051)
              2x RF2001 (D16041)
              2x 5.6 ohm SMD resistor
              1x BD8694 IC
              I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
              03-21-2023, 08:33 PM
