Sanyo 50" plasma dp50747 Vertical line
  • jsrwild
    • Oct 2012
    a 2" black vertical line just showed up on my tv. how can I try to repair it myself? is it repairable?
    your help is greatly appreciated,
    thx in advance for any replies!
    Re: Sanyo 50" plasma dp50747 Vertical line
    It is likely a failed plasma panel but on an older panel it could be a loose connection or a cold joint on the flex.
    Dave Jones with a similar issue with a Panasonic:
    http://www.youtube.com/watch?v=FXy2jHNpv_0&t=7m10s
    • otaku_nut
      Vizio E701i-A3 fixed but now has red vertical line
      by otaku_nut
      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
      08-19-2025, 06:11 PM
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
    • almarhum
      To fix laptop screen vertical line by working on its EDP cable
      by almarhum
      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
      05-07-2024, 02:12 PM
    • mrsith
      Samsung UE58TU7100K - no picture, vertical line
      by mrsith
      Hi.
      Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
      This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
      Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
      02-07-2023, 11:18 AM
    • canadaboy25
      LG 50PG10 Plasma Vertical Line
      by canadaboy25
      Hey guys, I'm being offered an LG 50PG10 plasma with a vertical line running down the screen.
      Apparently, if you give the TV a good smack on the frame above the line, it will go away for a while.
      Does this sound like a bad solder joint or loose ribbon cable? Or a bad panel? If it's not likely to be a bad panel I will likely pick it up.
      What do you guys think?
      Thanks...
      11-24-2020, 11:50 AM
