Vizio VOJ320FLA
+ More Options
Posts
  • abakes98
    • Oct 2012
    • 9
    • United Ststes
    Vizio VOJ320FLA
    I have a Vizio VOJ320FLA, which isn't working properly, and I'd like to repair it. The top half of the screen is blue with a no signal warning, which isn't surprising because there is no signal, but the bottom half is a black screen. Antone have any input?
    Re: Vizio VOJ320FLA
    When you hook it up to normal video do you get the same half screen issue?
    Is the distinction between the halves sudden, or gradual? Does the backlighting change? (check in a dark room if unsure.)
    It is likely to be t-con or the LCD panel. It is plausible though it could be the main board.
    • abakes98
      • Oct 2012
      • 9
      • United Ststes
      Re: Vizio VOJ320FLA
      Ummmm, it's instant. On the bottom, black half there are some, for lack of a better term, lines cast down vertically from the midpoint. It's almost as if the picture is really trying on the bottom, but it just wont happen. When the bouncing screen saver moves toward the bottom, it disappears into blackness and if I raise the menu, I can only see half of it.
        Re: Vizio VOJ320FLA
        The few vertical lines make me think it might be an LCD panel failure. Did the problem occur immediately or did it get worse slowly? Was the TV hit, or impacted in any way?
        • abakes98
          • Oct 2012
          • 9
          • United Ststes
          Re: Vizio VOJ320FLA
          I believe it was a spill actually. I was thinking it would be better if I never had to say those devil words, but for the greater good, I'll relay what I was told. Also, they aren't lines per se; it was the best description I could give is all.
          • kevinm34232
            • May 2012
            • 1884
            Re: Vizio VOJ320FLA
            You mean it dropped or something spilled on it? I'm assuming you mean it fell?
            • abakes98
              • Oct 2012
              • 9
              • United Ststes
              Re: Vizio VOJ320FLA
              Oh.. aha!-haha! I mean some sort of children's liquid was spilled in it. I don't know if it was on when the incident occured, but I know it was plugged in. It didn't work at first at all...until I replaced the fuse, then, when it did...Well, you know.
              • abakes98
                • Oct 2012
                • 9
                • United Ststes
                Re: Vizio VOJ320FLA
                The fuse took alot of work by the way. I had to dig the old solderer out.
                • kevinm34232
                  • May 2012
                  • 1884
                  Re: Vizio VOJ320FLA
                  Do you see where the liquid actually went??
                  • abakes98
                    • Oct 2012
                    • 9
                    • United Ststes
                    Re: Vizio VOJ320FLA
                    Nope. Can't find any damage either. I'm lost on it.
                      Re: Vizio VOJ320FLA
                      LCD panels can be damaged by water.
                      Problem with Sony due to water damage: http://www.youtube.com/watch?v=yqcqDQFqZHo
                      It is important when any electrical device gets water on it for the device to be unplugged as soon as possible, and for the device to be thoroughly dried before it is used.
                      It may be fixable, but I suspect the LCD panel itself has had damage done to the source driver ICs. These are embedded in the LCD screen, and are generally unreplaceable. It may be possible that some latent water is still stuck inside the screen; if so, cleaning that out -may- fix the problem.
                      • abakes98
                        • Oct 2012
                        • 9
                        • United Ststes
                        Re: Vizio VOJ320FLA
                        I was really hoping I wouldn't have to open that. That's all new to me.
                        • abakes98
                          • Oct 2012
                          • 9
                          • United Ststes
                          Re: Vizio VOJ320FLA
                          If I let it sit for a few days, you think it might work itself out.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Re: Vizio VOJ320FLA
                            Though the t-con is more exposed on the top than the panel so who knows.. I think it would be worth opening and looking at the t-con board for "childen liquid" lol.
                            • abakes98
                              • Oct 2012
                              • 9
                              • United Ststes
                              Re: Vizio VOJ320FLA
                              Yeah. I should have gotten a better run down of what happened to it. ugh
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
                              • SS454
                                vizio e650i-a2 backlight flashes then turns off
                                by SS454
                                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                panel: au optronics T650HVN05.4
                                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                08-20-2020, 03:57 PM
                              • gavric
                                Vizio M70-C3 Half picture is bad, main board on its last leg?
                                by gavric
                                Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                When tv powers on vizio V logo shows nice on whole screen. picture 1
                                When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                When i click video to start playing picture goes black(like when you change...
                                09-02-2021, 08:55 PM
                              • Formaster
                                Sony KD75XE9005 Bottom half double image
                                by Formaster
                                Hi guys,
                                I'm tyred from these sympthom, if anyone helps me really big thx.
                                When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
                                08-10-2021, 06:57 AM
                              • Fly_Among_Stars
                                VIZIO E70-E3 Half picture with half TCON
                                by Fly_Among_Stars
                                I have a VIZIO E70-E3.
                                Symptoms: Black screen, no picture, but LED backlights are working.
                                I probed the power board and voltages are as listed on the board.
                                Main board appears fine, too.
                                I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                There are two separate ribbon cables feeding the LCD.
                                If both are connected, the screen is black.
                                If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                04-24-2023, 08:20 PM
