Re: Sanyo DP42848 42" LCD TV: sound, but no picture
I have a dp42848 as well and have similar issue (ie. the 2 second black out) however after some fiddling I was checking the voltage across the wires to the bulbs on the inverter board (the pink on and the white one) When held there the tv work perfectly. However when I removed my leads the screen went black again. Any idea what it would be on the inverter board?
As expected, there is a burned out CCFL. It may not be easy to tell in the attached photo, but it is the 5th one up from the bottom. I will order one from CCFL warehouse and see if I can get this thing back together without damaging the panel. Wish me luck!
I was able to still get them soldered nice and good without melting away too much of the metal. Then, upon reassembly I had forgotten how some of the frame pieces went together and I had to install and remove the panel about 3 times until I finally got it right. At this point I was certain I damaged the panel just from moving it around so many times. I thought to myself, it would be a miracle if this TV still worked. Well, when I finally got the panel reassembled and the connections hooked back up, I powered it on and to my surprise IT WORKS!!! That's a 42" TV rescued from the dumpster and only $20 of parts put into it!
Been using it for a week now and no issues at all. Hopefully it still has some years of life left in the other lamps! Take care!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
