Sharp Aquos LC-32gp1u
  • Segalus
    • Oct 2012
    Hello guys,
    I'm having an issue with my Sharp Aquos. When It powers up right side of the LCD is distorted. It kind of looks like this:
    The only difference is that on My TV the distortion is the whole right half.
    After turning off the display repeatedly and waiting for the relays to click the TV will eventually work but that can take up to 30 minutes. Also once the TV does Turn on properly it does not have any issues.
    Re: Sharp Aquos LC-32gp1u
    I do not think it is related to the relay problem, relay cannot make part of the screen to be bad. I would try reseating the ribbon cables between the main baord and the T-CON board first.
      Also, see this video if budm's suggestion doesn't fix the problem:
      http://www.youtube.com/watch?v=purk_SyiT44
      • Segalus
        • Oct 2012
        Thanks for the advice I'll check it out when I get home from work. My only concern is that this is only an issue when I first turn on the TV for the day.
        Normally I'll get up turn on the TV and the right 1/2 will be distorted. After powering it up 10 to 20 times the distortion will be gone and the TV works fine for the rest of the day. The issue only happens if the TV has been off for many hours. It seems like my TV needs to warm up and that's whats throwing me off. A cable or ribbon issue would make this happen randomly and not just on a cold boot. Think it could be the T-CON board or something else ?
          You can also try cooling the T-CON board after warm up to see if the problem occur, or warm up the T-CON board with hair dryer before turning the TV on.
          • mymac80
            • Nov 2012
            Segalus, I have the exact same model with the same issue. I'm curious to know if any of budm or tom66's solutions worked for you.
            • scubacamper
              Sharp Aquos LC-70C6400U Half Screen Dark
              by scubacamper
              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
              05-03-2025, 12:19 PM
            • sefoster
              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
              by sefoster
              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
              11-20-2022, 09:29 AM
            • jonah1024
              Sharp Aquos LC-40UG7252E LCD TV burn in?
              by jonah1024
              Hello!
              I'm a few days old into this TV screens repair universe so please bear with me.
              Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
              - I did the classic unplug and hold power button to discharge the caps but it didn't help.
              - I did a factory reset as well...
              07-16-2024, 04:23 AM
            • klassic
              Sharp Aquos LC-60LE635E three blinks
              by klassic
              Hi community,
              I will describe my problem with a TV in those short following terms to be the most precise :
              What i have :
              power board DPS-162KP-1
              main logic board QPWBXF733WJN2
              symptoms :
              white led light logo at startup,
              after 2 minutes, blinking 3 times a row, repeating
              no backlight (and apparently no picture, checked panel with flashlight)
              no startup sound
              powerboard investigations :
              1-2 PNL : 0v
              3-4 GND
              5-6-7-8 UR : 13.15v
              9-10-11-12...
              10-24-2023, 01:39 PM
            • foxyUK
              Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
              by foxyUK
              Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
              The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
              There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
              10-22-2024, 10:27 AM
