philips 37" lcd blinks and wont turn on,,
  • A1TVyu
    • Apr 2010
    Re: philips 37" lcd blinks and wont turn on,,
    Thank your Tips, I have this model LCD TV for fix. It is also Resistor 3318 open circuit. I use 3 X 330 ohm 1/2W in parallel connection to make one 110ohm resistor 1.5w to replace the open circuit 100ohm. now it is working fine and is under testing for few hours. if every thing OK I will call back my customer and deliver back it him. or resell it out.
    I have the service manual for this model. please tell me how to upload to this site. or any TV guy want it. Please email me at yuming@sbcglobal.net
    I will email you one copy.
    I got it from other site Mr. Eric who is a very powerful young man and very kind & eagerly to help other guy who need help & information.
    I am old man at 70 year old, Please help me don't drop me down. Thank you.
    Thank you.
    A1tvyu
    05-25-2014
    • alfonsoreyesd
      • Mar 2014
      • 29
      Originally posted by RON_CET
      power supply check for open resistor location 3318 see attached image
      you got it, thanks my tv works now
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • ovrax
        Philips 55PUS6804/12 turn on & off (probably backlight issue)
        by ovrax
        First of all, please excuse me as I'm quite new to this field.
        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
        The Ambilight works perfectly and stays on.
        No sounds.
        Thanks in advance.
        08-25-2024, 04:33 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
