Samsung UE40B6050 standby supply blown
  • PowerAmpFreak
    • 982
    • Sweden
    The set has a blown standby supply. Unfortunately I can't see number on standby IC anymore. It's designator ICB801.
    Does anyone know what IC this is?
    Re: Samsung UE40B6050 standby supply blown
    Please post good clear pictures of the board, use the attachment function.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Is it an 8-pin IC?
      Could be an ICE2Bxx65 or ICE3Bxx65 series. Have a look at the ICE3B0565 data sheet for example, and see if the pinout functions of the IC on your board matche the pinout of the ICE3Bxx65 series chips.
        Part number of board.. BN44-xxxxxx?
        May be able to look up schematic or parts list.
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
          09-07-2024, 05:50 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • alltvrepairs
          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
          by alltvrepairs
          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
          Any one met this problem in the past?...
          10-08-2025, 07:34 AM
        • Kaar3l
          Samsung QLED QE65Q7FNAT only standby light
          by Kaar3l
          TV: Samsung QLED QE65Q7FNAT
          PSU: BN4400940A
          MB: BN94-12832K
          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
          09-24-2024, 01:35 PM
