fsp271-4f01 repair and wire coding - schematic?
  • Zalinar
    Zalinar
    • Sep 2012
    • 10
    I am repairing a fsp271-4f01 power supply. I have searched all threads here, and the fspgroup web site has no schematics for this supply.
    Does anyone know what the wires do on CNS1? The Orange wire is 5v standby and that is all I have figured out. I need to know how to 'turn on' the power supply. Usually, the standby voltage pin should be connected to the O/F pin, but I do not know which that is. I have tried various combinations, but still only have the 5v standby - nothing else.
    I have replaced 3 mosfets (Q3, Q4, QS6), and now I suspect IC3 (IR2184S). I read only 5.2 ohms between pins 4 and 5 - almost a short.
    Bridge rectifier, caps, fuse, and all else appears to be good.
    There is also a dead short (0.00 ohms) on ICS1 and ICS2 between pins 3 and 5. I can't read what these are, so I can't find a datasheet to determine if thus is normal.
    Suggestions?
    I really need a schematic and to know what all of the wires do. I emailed FPSGROUP and requested a technical drawing, but there was no reply.
    Thank you for your time!
    ~Seth
  • Hobby 1
    • Mar 2010
    • 86
    Re: fsp271-4f01 repair and wire coding - schematic?
    What device is this power supply from? Brand and model?
    • ntoskrnl
      • Sep 2012
      • 17
      • Finland
      Is it an ATX power supply? The "power on" wire is usually bright green. Short it to ground and the unit should come alive.
      Also check the ATX connector pinout: http://en.wikipedia.org/wiki/ATX#Power_supply
      • Mr Bill
        • Nov 2011
        • 648
        It's either for an olevia or syntax LT42HVI. I've had the pleasure of complete failure trying to repair this supply. Q3, Q4, & QS6 were shorted on mine too plus the fuse. I replaced those components and tv still refused to turn on. I do remember testing alot of componts in circuit and they would read shorted but after i removed them they would test good. I tried calling FSP group and they never answer the phone or return messages about having it repaired. There was a repair service on ebay but by the time i saw the listing i had already put my majic touch on the board and they would probably have sent it back
        Some people have replaced just the mosfets and fuse and the tv worked so hopefully you'll be in that group.
        • Zalinar
          Zalinar
          • Sep 2012
          • 10
          I am pretty sure it is from a Syntax LT42HVI. I am repairing it for someone else. I successfully repaired one previously, but this one is giving me trouble like you said Mr. Bill. It is an FSP not an ATX.
          Thank you everyone!
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • Yanleb
            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
            by Yanleb
            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
            Disconnecting the main board from the power supply makes the backlight come ON.
            I did disconnect the panel cables and the WIFI modules, the board is still dead.
            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
            Thanks.
            11-18-2024, 12:34 AM
          • reessi
            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
            by reessi
            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
            Years ago it had some bulging caps...
            04-26-2021, 11:42 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
