HAIER HLT10 No video no power won't turn on
Re: HAIER HLT10 No video no power won't turn on
I still cannot see how the two pins of the lamp connector connected to in the pictures. Can you see?Never stop learning
I mean the closed up connection of that connector, I am trying to trace out the copper traces to se where the two traces from the connector go to.Never stop learning
Yes you are right. There is no clear indication of copper trace on the board. Do you think this board has any fuse on it?
I hear faint buzzing noise coming from the board while connected to power supply. BUT no LED light .
I am getting 3.32v and 5.56v from this U10 voltage regulator.
should I just go ahead and change all the capacitors? Although there is no sign of bad capacitor.
Obviously the LCD panel working but no LED back light. Even the power RED LED does not even light up unless I connect the battery.Last edited by arman960; 09-30-2012, 09:13 PM.Comment
I am si sure about the power LED, the thing is that you can see that there are images on the screen so the processor and video processing are working. We just need to find out how the LEDs get its power from. U10 seems OK with typical 3.3V output. By the way, do you get sound?
If you have adjustable power supply with an adjustable current output to about 20mA, then you can try lighting up the LEDs with it.Never stop learning
yes sound seems like working also. Because when I turn the power on I hear noise from the speaker. But not sure if the sound works or not. I cannot tune any channel.Just the back LED not working. I will supply power to LED panel and see if lights up. There is almost no output from that cable for the LED panel. Close to zero.
There are lot of small voltage regulator on it. All of them seems like working.Last edited by arman960; 09-30-2012, 09:45 PM.Comment
Just be careful that you must limit the current through the LED to about 20mA for testing.Never stop learning
It will be more than 5V since typical Vf of White LED is about 3.4V. Since we do not know how many LEDs are in this screen, it can be 4 or more. That is why I suggest the power supply with adjustable current regulator so no matter what the load is, it will always limit the current to 20mA setting.
http://white-leds.co.uk/led-wiring-guide.htm
You can the setup as shown to see if will light up at all.Never stop learning
Ok. I will try this way and post the result.Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
Assuming...7 Photos -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by Journey11Hi All,
First time posting here ... my name is Kevin but my friends call me Journey.
I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again.... - Loading...
