Hello all have a non working hitachi l40c205 that someone was throwning out. Tv originally didn't power on at all. Upon inspecting the power supply(rsag7.820.1673/roh ver f) I found that the glass fuse was blown and the triac at v811 cracked. When I replaced the fuse and plugged cord in v811 threw sparks and the fuse blew again. I picked up what i was told was a re-manufactured power supply off ebay. Now when i plug it in i hear one click(sounds like its coming from power supply). The red power light comes on however the set doesn't power on. I don't have the remote for the set and the power button is the touch setup. Is there a way to turn set on via jumping any connections. Any tests st this point would be helpful before i place it back out on curb... thanks
hitachi l40c205
Re: hitachi l40c205
Wow, it looks like it cracked that green varistor.....wonder what caused all that
Anyways, on the power supply, what are the voltages.
Now, just to clarify, with the new p/s, it has a red standby light but that's it? Power button does nothing at all? or does it go to a red light?
That blue cap looks like a plastic film type; it should be fine.Last edited by drpj23; 09-26-2012, 06:54 PM.Comment
Re: hitachi l40c205
As soon as it's plugged in the light on front comes on red. I do not have the remote for the tv and all the controls on the set are touch. When i touch where it says power nothing happens at all. I tried programming a few universal remotes with no luck. I'm not sure if the problem is in the power supply or the controls. Can you walk me threw where to test for voltages on the power supply?Comment
Re: hitachi l40c205
You should have a standby voltage of about 5v on one of those connectors.....but include a pic of the printed legends.
This is sounding like a main board fault since that cuts on the p/s to provide power to the rest of the boards.Comment
Re: hitachi l40c205
Ok that is good. You will not have any other voltages since the power supply is in standby.
Your glass fuse is good since you are getting the 5v and has AC not DC going across it.
And lastly I would not replace parts from the "new" board. Buy parts from a place like digikey so you are not stuck with two non-functional power supplies.
I'll do some research later on that power supply but budm or tom66 can help you faster than I can research. I am very tired lol
Oh I do suspect a prob with main so could you please include pics of it.Comment
Re: hitachi l40c205
You want to check SW. If it is changing when the power button is pressed, but the voltages aren't coming up, it points to a power supply problem. If it's not changing, then it points to a main board problem.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: hitachi l40c205
you should be able to use one of the mounting screws as a earth for your meter then test from the top of the connectors just push the red lead in untill it makes contact then note each reading.Comment
Re: hitachi l40c205
Ill check the voltage while hitting the power button as well as with all connectors plugged in. This set has touch controls on the front. Is there a method of jumping points on that board or main board to see if issue is with board....wish it was standarnd tactile buttons.Comment
Re: hitachi l40c205
It's on the PSU, pin marked SW. Likely the on/off control.
You may be able to locate the connector for those buttons and find the pins that correspond to the power button, then jumper those to send the signal to the TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
