Panasonic TC-P50G10B - flashes 7 times, stuck in standby
    Nice 50", Freesat HD/Freeview HD, full HD 1080p plasma here for repair. Panasonic G10 series - pretty new stuff! (approx 2 years old I think.)
    Picked this one up today with sienoki - anyway, the fault is that it's stuck in standby with the all too common 7 red blinks issue. This is an SC, SU or SD board fault: likely SC, with a shorted FET if I'm lucky. Could be buffers too. I've had 7 blinks before and was able to isolate a FET and get the set to run well.
    More info tomorrow when it's disassembled!
    edit: it's TX-P50G10B because it's the European version. US version is TC-P50G10.
  • allsmith
    • Aug 2012
    • 179
    Re: Panasonic TC-P50G10B - flashes 7 times, stuck in standby
    Sounds like a nice one! I hope you get it up and running,Im sure you will!
      OK, got it in the dorm... very big TV.
      Think I have isolated SOS7 as coming from the SC board, it fires up briefly to 4V then the TV cuts off with the 7 blinks. Now trying to find a way to disable it temporarily and see if I can get a picture.
        Vad is -40V from GND_BASE; this is good.
        Vscn is -185V from GND_BASE, also good.
        Disabled SOS7 and then it gives me SOS6. So not erroneously detecting a fault, there's definitely something up on the SC.
        SOS7 definitely spikes up to 4V on my scope for 200ms.
          Bingo... the specific fault is the VSCN. There's nothing wrong with it, but it is detecting a fault, probably undervoltage lockout. Collector of Q876 and R752 is firing the pulse into the OR-diode, which sends SOS7 to the A-board. Need to figure out why though.
            I'm getting a spike on SOS7 that's not being generated by the SC, I think. It's not on either of the anodes of the diode OR-logic. So it's coming from somewhere else. There is a little spike but it occurs on shut down and start up only, so I think that's OK. I may be wrong.
              IC561 is generating the shutdown pulse. It's not happy with something... Need to figure out why but it's definitely coming from there, must have missed it in the schematic.
                MAIN_STOP0 is going high, which is buffered by the IC561; this then OR's the fault onto SOS7. Need to find out why MAIN_STOP0 is firing. Possibly a bad FET somewhere; maybe not firing as it should. Page 74 has the main stop detection circuit. Time to look at that.
                • tw2005
                  • Oct 2011
                  • 6458
                  did you find any shorted components?
                    Not yet. There might be some tiny SMD diode shorted or open or something similar out of tolerance; but all big power FETs/IGBTs/diodes test OK.
                    SOS7 with the MAIN_STOP0 firing could be caused by SCRN_PROT, low isolated 5V or CHA protect (whatever that is...)
                    Also noticed this TV has ethernet. Smart TV features??
                    • tw2005
                      • Oct 2011
                      • 6458
                      Just had a quick look at the schematic. Design looks similar to the P42X14 I isolated the sos7 with a low VAD and adjusting the pot made no difference for VAD.Pot was good.
                      MIP9L02 was the ic for VAD on mine too.
                      What did you do to isolate sos7?
                        Checked around all the SOS7 test points to isolate it. VAD and VSCN are good and adjustable. VSUS was set too low, so I adjusted it to the panel sticker (206V; was 199V.) Someone has been in here before me, there are some screws missing - I hope nothing else has been messed with.
                        Have now found the 16V line only hits about 3.5V or so before SOS7 falls over; some how it's being held down. It's provided by a little plug in hybrid module, which will be a bugger to find a replacement for... argh.
                        The 16V provides power to the 5V sub reg, which gives some of the SOS7 protection ckt power to signal CHA, SCRN_PRO, 5V UVP or OVP (not sure), and 16V OVP (possibly also UVP - it's a bit difficult to understand - I may end up simulating the circuit in LTspice.)
                        So it definitely does a lot of things for one error code! I guess Panasonic just expect a board swap.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Geez mate ease up on all the techno stuff, I'm getting a headache with all the abbreviations.. Are you studying engineering or something?
                          I misunderstood you, I took isolate to mean disabled. How did you disable sos7?
                            MEng ElecEng undergrad , at the University of Leeds... arrived about a week ago.
                            The abbreviations I've used are the ones Panasonic used. I have no idea what most of them stand for except UVP = under-voltage protect, OVP = over-voltage protect, ckt = circuit.
                            Disabling SOS7 can be done by shorting the test pad to ground. I used the 10A range on my meter. SOS7 was zeroed, but then SOS6 triggers because there's another fault... I'll guess the low 16V is part of that as it provides power for a few other things. Isolating it means trying to locate the specific error causing the SOS7 shut down.
                            • tw2005
                              • Oct 2011
                              • 6458
                              When I was young I started Elec Eng, got lazy and quit. Wish i followed it through. Now just a tech in a place that justs board swaps and no deeper level stuff.
                              Still interested in how you removed the SOS7.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Well that was easy compared to what I did. I went invasive and cut a track + removed a tiny double diode(don't know what to call it)
                                    Double diode is the term. All the SOS7 has 4.7k resistors in series, I checked, it limits current due to short circuit so is OK.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Did you mean VAD = -185 & Vscn = -40V?
                                        Measured relative to the case of the TV. But in reality, VSCN is relative to VAD... around 145V. It's pretty complicated to drive a plasma panel! It amazes me the newer Samsung plasmas have got it down to just 8 devices on the Y-main and three on the X-main. There's nothing to it on them. They probably won't last too long though; maybe just getting out of warranty.
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
                                        • BobbyMJ
                                          Panasonic TC-P60S30 - no standby voltage
                                          by BobbyMJ
                                          Hi All,
                                          Wanting to learn some electronics repair skills.
                                          I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
                                          So far I have found a blown cap on the main power supply board.
                                          After replacing it there's still no standby power.
                                          Poked around and found a resistor on the PSUB power supply board that measures open.
                                          An online resistor calculator shows this is a 93k ohm resister.
                                          My questions:
                                          Is that correct, 93k ohms?
                                          Is it a fusible resistor?
                                          Lastly, how do I know what wattage?...
                                          05-14-2025, 06:42 PM
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • ayecrut
                                          Problem switching on LG TV, red LED flashes 3 times
                                          by ayecrut
                                          I have picked up an LG brand television, manufactured in 2014. The model is LG-49UB850V / LG-49UB850V ZD (Link).
                                          When I tried to start it the first time it didn't work, the screen remained black and the red LED blinked 3 times or just stayed on all the time. After moving it and plugging it in somewhere else, it restarted once or twice, but since then it hasn't started with the same symptoms.
                                          Other information:
                                          - The physical button that turns on the TV without the remote doesn't seem to work. Nothing happens when you press it, we can only...
                                          02-09-2024, 05:25 PM
