Sony KDL-46XBR4 13 blinks
  • tieny
    • Feb 2012
    • 478
    Re: Sony KDL-46XBR4 13 blinks
    Alright so I disassembled it down to the CCFL's, and clicked the power on button. I checked all of the ccfls as they lit up, there was about 24 of them and I noticed that one of them was flickering. Would the flickering CCFL be the cause of this problem?
    Heres a video:
    http://www.youtube.com/watch?v=8tzzh...ature=youtu.be
    its the 4th lamp down from the top, the TV turns on, and as the lamp starts to flicker the TV turns back off.
      Heres a video:
      Almost certainly (>90%) the problem. Replace it or do the bypass - your call.
      • tieny
        • Feb 2012
        • 478
        Good news here! Turns out the flickering was due to a loose connection of the ccfl to the side connectors. There was a couple of loose connections than the flickering one, I fixed the connector and rehooked every ccfl, now the TV actually stays on! =) Lets hope it was the only problem, reading alot about this TV i feel the tab bonding problem may arise (lets hope not!)
          I hope that fixes it! Nice fix if so...
          Someone else on these forums had a similar problem, arcing backlight connector due to it not being completely secured.
          • tieny
            • Feb 2012
            • 478
            So just put everything together, theres a little uneven lighting from the backlights but not too noticable, especially when the picture is playing. But everything is working great!
              You probably smudged the screen, it can be cleaned on the inside with a cloth.
              • caseyjay_48
                Sony KDL-46BX450 Inverter Troubleshoot Logic
                by caseyjay_48
                I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                09-23-2022, 08:08 PM
              • jason123
                Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                by jason123
                Hi there,
                I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                I see 2 posts that are relevant:
                https://www.badcaps.net/forum/troubl...j-oled-5-blink
                https://www.badcaps.net/forum/troubl...g-hardware-dev...
                10-29-2025, 02:01 PM
              • matwan
                Sony XR-55X90J 5 blinks
                by matwan
                I have problem with SONY 55X90J. After several check status is as below;
                1. Running power board as stand alone:
                TCON_12V =~ 12.6V
                EVDD V On Max 24V= 19V.
                2.
                Running power board with TCON as stand alone:
                Effect as below, attched.
                3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                Best regards....
                09-28-2025, 04:26 AM
              • GoodCapDude
                Sony XBR-75X940E intermittent 6 blinks error code
                by GoodCapDude
                Hi everyone. First post on Badcaps!
                I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                09-20-2025, 06:07 AM
              • AK_777
                Sony KD-65A1 Repair – 4 Red Blinks Error
                by AK_777
                Hi everyone!
                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                02-20-2025, 04:15 PM
