Lg 50px5d-ab firmware upgrade dtvlab
  • tw2005
    • Oct 2011
    • 6458
    Anyone tried a firmware update using the service port before. I got the software and file but can't get it to flash.
    Connected to the TV ok, screen on set went to update, followed the instructions, selected the file for the 50px5d-ab, decompressed, unpacked and ended with "downloading application size too enough (3276312) > (3211264)!!!"
    what went wrong?
    03:51:06 - 50PX5DAB
    03:51:08 - D
    03:51:08 -
    03:51:08 - [DEBUG Main Menu]
    03:51:08 - 0x10: System menu
    03:51:08 - 0x14: Sevice download
    03:51:08 - 0x15: factory menu
    03:51:08 - 0x20: NTSC menu
    03:51:08 - 0x25: ATSC TP menu
    03:51:08 - 0x30: Audio menu
    03:51:08 - 0x35: Adec menu
    03:51:08 - 0x40: Vdp menu
    03:51:08 - 0x41: DebugHd2chip
    03:51:08 - 0x45: Vdec menu
    03:51:08 - 0x50: Front End menu
    03:51:08 - 0x70: Gpio Test menu
    03:51:08 - 0x80: DVI Test menu
    03:51:08 - 0x88: Channel Manager menu
    03:51:08 - 0x99: PSIP menu
    03:51:08 - 0xa1: Closed Caption menu
    03:51:08 - 0xaa: KBPS menu
    03:51:08 - 0xb0: ADJ RGB Value
    03:51:08 - 0xb1: Restore RGB Value
    03:51:08 - 0xbb: UI menu
    03:51:08 - 0xc0: UART PRINTF menu
    03:51:08 - 0xc1: PalTuner debug
    03:51:08 - 0xd0: OSD menu
    03:51:08 - 0xd1: RF switch
    03:51:08 - 0xd2: EPF menu
    03:51:08 - 0xf0: Flash Download
    03:51:08 - 0xf1: Fast Power On
    03:51:08 - 0xf2: CTO ZOOM Test
    03:51:08 - 0xfd: DLP debug
    03:51:08 - 0xfe: Display Version INFO
    03:51:08 - 0xff: EXIT from Main DEBUG Menu
    03:51:08 -
    03:51:27 - Select Command: 0xF0
    03:51:27 -
    03:51:27 - [FLASH Download Menu]
    03:51:27 - 0x1: Download Application!
    03:51:27 - 0x2: Download CPLD
    03:51:27 - 0x3: Go to Boot up menu!
    03:51:27 - 0x4: System Reset
    03:51:27 - 0xff: Exit from this menu
    03:51:27 -
    03:51:36 - Select Command: 0x1
    03:51:36 -
    03:51:36 -
    03:51:36 - ================================================== ==
    03:51:36 - == ==
    03:51:36 - == FLASH ROM Code Downloader V0.90 ==
    03:51:36 - == ==
    03:51:36 - == for LGE Affordable HDTV Board, thru Serial ==
    03:51:36 - == ==
    03:51:36 - Description : Affordable Boot Code
    03:51:36 - Compiled by : choiyunjung
    03:51:36 - Compiled at : Thu May 26 16:38:34 2005
    03:51:36 -
    03:51:36 - DON'T PRESS THE KEYBOARD!!!!!
    03:51:36 - I'm ready, send binary data(application rom.pak)
    03:53:49 - ################################################## ################################################## ################################################## ################################################## ################################################## ######03:53:49 - 0x144424(1328164) bytes received.
    03:53:49 - Serial binary download completed.
    03:53:50 - CRC check about downloaded image ... O.K
    03:53:50 - Expand the compressed image at 0x0c700000
    03:54:28 - 100%
    03:54:28 - Unpacked from 0x144416 bytes to 0x31fe18 bytes
    03:54:28 -
    03:54:28 - FLASH manufacturer ID = 0x001f001f
    03:54:28 - FLASH device ID = 0x88c388c3
    03:54:28 -
    03:54:28 - !!! ERROR : Downloading application size is too enough(3276312 > 3211264)!!!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Lg 50px5d-ab firmware upgrade dtvlab
    It says the new image is too big to fit.
    A working TV? How boring!
    • tw2005
      • Oct 2011
      • 6458
      I got the solution from someone. The boot code has to be updated first with another file to allow for the larger size. Did that and upgrade now loaded.
      • cheebster
        • May 2008
        • 376
        tw2005, how do you proceed to upgrade the firmware on lg plasmas ? i've never seen much info on how to do this, hardware and software wise ? thanks in advance
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • zoltor
          Canon G3430 has a lightning flash after the firmware
          by zoltor
          Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
          09-17-2025, 12:40 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
