LG 42lg3000 TV
  • Berts
    • Aug 2012
    • 55
    • Scotland
    LG 42lg3000 TV
    Hey,
    I was using another forum to diagnose my problems with a LG 42lg3000 TV
    You can view the forum here: (hope I am not breaking any rules posting links to other sites?)
    http://www.techsupportforum.com/foru...ml#post3852028
    Basically I have replaced all the boards in the TV and it now powers on and stays stable sometimes, but I can work out what the problem is a why it only works either when I constantly bang it or when I turn it on / off or sometimes when I disassemble and reassemble.
    Any ideas to get this sorted?
  • drpj23
    • May 2012
    • 528
    Re: LG 42lg3000 TV
    Ok I am having a hard time understanding the last part of the sentence.....so it only cuts on when you bang on it (while pressing the power button or just cuts on? or both?) and works intermittently upon assembly and dis assembly?
    And do you have a hard time getting the tv to cut on, stay on, or both?
    Either way, it sounds like bad connections/connectors or possibly a bad solder joint I would say caps too but you said you replaced the boards.
    • Berts
      • Aug 2012
      • 55
      • Scotland
      Re: LG 42lg3000 TV
      Sorry, I can see why you are getting confused. My English was terrible in the last post.
      If it turn the TV on, it stays on. Dark at first then gets brighter, all pix-elated. Sometimes the screen just shows tearing on the Y- axis. If I lay the set on its face and stand it up again, it springs into life and the pictures shows up perfect.
      I guess it must be a loose connector as I have changed all the boards. Guess I will take it apart again and double check everything.
      • drpj23
        • May 2012
        • 528
        Re: LG 42lg3000 TV
        Ok, so if you are having visual problems then yes, recheck your cables - especially the LVDS cable from the main to the TCON and also the ribbon cables from the TCON to the panel while making sure the ribbons are seated correctly before clamping them down.
        • fab13
          Power supply PS4 FAT - ADP- 240R cuts 12 Volt in 1 sec -Why?
          by fab13
          I have a PS4 FAT edition chu-1000a with the power supply (ADP-240R) that is acting up.
          After checking that it comes from my power supply and by activating the 4.7Volts with clamps, the 4.7
          The power supply starts, but cuts instatantly with a small snap on the primary side and after measuring the voltage which climbs to 10 Volts at the start and drops.
          - No short circuit around the DPN012A chip (Probably the voltage regulator for the 12 V output)
          It looks like an overload and the power supply goes to safety
          - No primary...
          04-05-2023, 04:15 PM
        • kjchatman
          playstation 5 crashes and cuts off while trying to playback a dvd movie
          by kjchatman
          the disc drive works perfectly because i can install games with it and it can read the movies.I can never get it to playback a movie disc. it goes to a black screen and sometimes a green screen then the console shuts down. It does it every single time i try to play a movie. The games also do the same thing If I don't start them up immediately after the console boots up. I've tried factory resets and replacing the ssd controller and the southbridge but nothing has resolved the issue
          11-11-2024, 06:52 PM
        • veedo
          Dell Latitude E7450 LA-A961P no power, charger cuts off
          by veedo
          HI
          I have Dell Latitude E7450 on my desk, doesn't power on, after plugin in the charger, light on the charger comes off.
          I found shortage and dead cap, without it laptop does turn on. But I cannot find value of that cap, just don't see it.
          motherboard ZBU10 LA-A961P
          Please help, maybe I'm just blind, I just have schematics not board view. Marked cap has been removed and laptop its turning on.
          Thank You
          10-25-2024, 05:38 PM
        • Nitro468
          15 Grand Caravan radio cuts out..
          by Nitro468
          My friends 2015 Grand Caravan, radio cuts out for a few seconds, then comes back... He had someone play with the antenna wires AM/Fm and XM.. it seemed to help... SO they jammed a screw by the antenna connectors and that works for about 2 months... Now its doing it again... I popped the cover off ad re-flowed both connectors... No joy... Any radio techs that can lead me in the right direction ?
          09-13-2021, 06:37 PM
        • Storyteller12
          Samsung Soundbar Q900T Cuts Off if Volume above 30
          by Storyteller12
          I have this soundbar and when I turn it on it works until I turn the volume above 30.
          Then the display show “PROT” protection and shuts off.
          I can turn it right back on and it works until volume hits 30 again.
          There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
          I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
          It will play fine for hours with volume...
          03-21-2023, 12:31 PM
