Power supply PS4 FAT - ADP- 240R cuts 12 Volt in 1 sec -Why?
  • fab13
    • Dec 2021
    • 109
    • France
    I have a PS4 FAT edition chu-1000a with the power supply (ADP-240R) that is acting up.
    After checking that it comes from my power supply and by activating the 4.7Volts with clamps, the 4.7
    The power supply starts, but cuts instatantly with a small snap on the primary side and after measuring the voltage which climbs to 10 Volts at the start and drops.
    - No short circuit around the DPN012A chip (Probably the voltage regulator for the 12 V output)
    It looks like an overload and the power supply goes to safety
    - No primary short circuit though
    - 4.7V standby well present
    Here is the schematic of the complete block.
    If some kind soul could help me or I could make my measurements from the diagram =D
    Thank so much
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
    I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
    I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
    I used a four USB outlet and electrical plate that is made for...
    08-03-2024, 07:54 PM
    After all of...
    07-13-2024, 08:14 PM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
