Vizio VO42L saga, Act 3: Signal tracing a T-Con board
  • mikew67
    • Aug 2012
    • 20
    Folks,
    Previous acts were reported in the following threads:
    So now I'm in act 3 of my saga, trying to figure out if the replacement T-Con board is bad or not. I do have a (150 MHz) dual-trace scope (and access to fancier ones). Looks like the next step is tracing signals in and out of the T-Con board. Which leads to the following questions:
    1. Is there any available tech info (general or specific) on expected signals in and out of a Philips 6870C-4200C T-Con board (question similar to a recent thread, https://www.badcaps.net/forum/showthread.php?t=22571)
    2. Curiously enough, I also have a 37" Vizio LCD TV of similar vintage. Haven't checked for T-Con similarity to the VO42L, but presume I could try comparing between the two. Advice?
    TIA,
    Mike
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio VO42L saga, Act 3: Signal tracing a T-Con board
    I'm in the same boat with you, trying to figure out if the T-con or the mainboard is at fault on a 52" Philips.
    • Fly_Among_Stars
      VIZIO E70-E3 Half picture with half TCON
      by Fly_Among_Stars
      I have a VIZIO E70-E3.
      Symptoms: Black screen, no picture, but LED backlights are working.
      I probed the power board and voltages are as listed on the board.
      Main board appears fine, too.
      I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
      There are two separate ribbon cables feeding the LCD.
      If both are connected, the screen is black.
      If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
      04-24-2023, 08:20 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • advant
      by advant
      02-03-2020, 12:25 AM
