Sony KDL46SL140 - Works when hot, doesn't work when cold
  • marls
    • Sep 2012
    • 6
    TV: Sony Bravia KDL46SL140
    If the TV is over 90 degrees warm, it works just fine, no problems.
    If the TV has an ambient temperature in the 70's or 80's it shuts off during some kind of power on self test. I see the Bravia logo appear on the TV but before I get any control of the TV (within 6 seconds) the relay switches the TV off. It will stay off until I unplug it and plug it back in.
    I've taken the back off and looked for swollen caps. I didn't see any obvious ones. I also used my magnifying glass to look for bad solder joints. Again I couldn't spot any.
    Since the TV has 3 main electrical boards I wanted to narrow down which board it was. I proceeded to heat up only 1 board at a time to see if I could get the TV working with just 1 board being hot. I tried this for 2 of the boards but even with the boards being hot the TV didn't stay on.
    I'm not sure what to really try next. Has anyone gone through something like this before that can offer some further advice?
    Thanks!
    Re: Sony KDL46SL140 - Works when hot, doesn't work when cold
    Have you tried reseating all connectors to see if it could be a loose one?
    Try removing the power supply board and checking for cold/cracked solder joints on the bottom of the PSU board. A bad solder joint looks like this:
    http://home.comcast.net/~tatng/Auto/...cked-joint.JPG
    • marls
      • Sep 2012
      • 6
      There are 3 main circuit boards in this TV. I'm not an expert, but one is where the power cable is terminated to which I believe is the PSU, one is where all the AV components plug in to, and another is probably a LCD controller bank.
      Today I took the TV outside to warm it up. It worked fine. I took out the PSU and AV board and put them in the freezer for 10 minutes. I brought them out and put them in the TV and it worked fine. This proves to me that neither the PSU or the AV board are the problem here.
      What else can I look for? Should I do the same with the LCD controller? Should I take out the board that has the power/volume button control? Should I take out the board that has the IR receiver/Status LEDs? Perhaps this is a connector that works when hot. Perhaps the florescent light doesn't work when cold?
      • marls
        • Sep 2012
        • 6
        Attaching picture of back of set. The two boards that seem to be ok when hot or cold is the orange one in the center and the blue one on the bottom right.
          Can you remove the orange board (PSU) and try resoldering any joints that look dodgy... like this: http://homepage.ntlworld.com/michael...Solder%201.jpg
          If that's OK, then the problem is possibly on the main board (blue one.)
          • marls
            • Sep 2012
            • 6
            Tom66, sorry for being a dork but, I feel like I've proved that the PSU and main board don't have a problem because they work both hot or cold. Looking for dodgy joints on those doesn't make sense to me. Can you explain?
              Completely my mistake, I misread your post. So, are you saying when you heat up that board the main board connects to, at the top of the LCD panel, the TV works? That is the T-con board.
              • marls
                • Sep 2012
                • 6
                I believe I have found the problem! The board on the far left which I think is the florescent bulb driver board is definitely the problem. When the entire TV is cool but that board is hot, the TV works.
                Upon examining this board I see some melted plastic pieces. I believe this is where the problem is but I don't know how to fix it yet. The plastic doesn't come off very easily to see what is under it. Attached are photos. Suggestions would be great at this point on how to fix the melted area!
                  Yes, that is the ballast board. This PSU is similar to Samsung and LG, but different from most other TVs, in that it generates one high voltage (approx 3000V) which is distributed to all the bulbs individually. Normally one voltage is generated for each. The black things (transformers) balance the current between each bulb and detect faulty bulbs. I suggest all you have is an intermittent contact, the arcing 3000V has burnt the connector. Use a scourer to clean off the surface and make sure the contact is properly cleaned. Reseating it too, as well as tightening the screws on the ballast board, could help.
                    SONY calls this Balancer board, it works as TOM said. I can see at least 3~4 more in pix #3 that the black plastic pieces are deforming. You should remove the board and clean the copper pads on the board real well with an eraser and then clean them with Alcohol. Clean off any carbon tracks that you can see also.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      WOW that is a big fire hazard!
                      Muh-soggy-knee
                      • marls
                        • Sep 2012
                        • 6
                        TV works great now. I cleaned the contacts just as suggested and now there is no buzzing or arcing. Thanks guys!
                          Glad to hear you fixed it! A very strange one indeed. Bud have you seen this before?
                          • foxer
                            Sony AV1010, basically works but heatsink is cold, resistors overheating
                            by foxer
                            Weird stuff.
                            I press power on this receiver, I hear the relay click, I can play music and get radio, everything apparently works but not really. The big heatsink stays cold to the touch, the small heatsinks to the two voltage regulators on the mainboard get super hot, and there are two overheated brown areas on the mainboard with an identical pattern (circled in red), centered on the components on each side of the big capacitors (removed in these pictures). Those last components, of course, also get burning hot.
                            So...I spent the week with my novice skill trying to locate...
                            06-19-2023, 07:54 PM
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
                          • Tempic
                            Sony KD-55XE7004 - No image, backlight works, new T-Con didn't help
                            by Tempic
                            I've got 2 broken TVs these are:
                            Sony KD-55XE7004
                            Sony KD-55XE7005
                            The 05 has a broken panel, everything else works fine, you can still see the image and menu through the cracks a bit.
                            The 04 displays no image. No Logo, no menu, nothing.
                            The backlight works fine, all LEDs are on and voltages on every series strip are the same.
                            The LED indicator blinks whenever I press something on the remote, so it does recognize it.
                            I was hoping to just swap the broken panel of the 05 with the working one of the 04.
                            05-18-2021, 03:55 PM
                          • dkneyle
                            Sony KDL-46HX850 Can't upgrade/update firmware
                            by dkneyle
                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                            09-25-2024, 10:44 PM
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
