KDL-46V2500 intermittent 4 blinks
  • avesteve
    • Sep 2012
    • U.S.A.
    Hello everyone, I have been lurking in the shadows for some time and have found a good deal of correct information posted here by some nice folks, I hope to be able to add to the collective wisdom at some point. The problem Sony at hand is throwing a back-light failure code but is terribly intermittent, sometimes occurring in 5 seconds and sometimes not for a day or more. There is no symptom in the picture to suggest that shutdown is about to take place, the screen is uniformly bright, devoid of lines, and is equally responsive in all areas. The power supply and all 4 inverter boards have already been replaced by the previous owner who said they made no difference. No amount of physical manipulation or temperature change will force the failure. Thanks for having me aboard, and thanks for any help.
    Steve
    Re: KDL-46V2500 intermittent 4 blinks
    Do you have a digital multimeter? Most Sony TVs will have a signal indicating an inverter/backlight failure, which can be tested. If this signal is showing an error, it could be a worn out CCFL tube.
    • high-tech
      • Sep 2010
      • 197
      Bad bulb or wiring
      • avesteve
        • Sep 2012
        • U.S.A.
        As luck will have it the set has been running fine now for 36 hours, picture is gorgeous corner to corner. I'll have to wait until it takes another spell before troubleshooting further, it might run for days. manipulation of wiring harnesses has no effect, nor does tapping on pcb's. I have changed lamps on laptop displays, are these replaceable too?
        • drpj23
          • May 2012
          • 528
          If you are meaning the CCFL tubes then yes...they simply pop out of the tabs that hold them in - but that does require carefully removing the LCD screen.
          • jdmvp
            • Feb 2014
            Hello, I came across this post and I have the same problem with my Sony Bravia KDL-46V2500. When I try to turn on the TV the screen stays completely black and the power indicator will blink red 4 times. I haven't been able to find any clear cut solutions online. Can someone please tell me what parts I need to replace in order to fix this issue? Thank you so much in advance!
            • fixme2024
              Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
              by fixme2024
              Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
              Here, I have attached a document...
              02-14-2024, 09:24 PM
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • peterzz2007
              Dell Precision 7510 intermittent POST failure
              by peterzz2007
              Hello all,
              i have troubles with Dell Precision 7510 board LA-C541P Rev:2.0 A01.
              It didn`t POST and it`s throwing 2amber and 1white code which is CPU failure.
              Sometimes it`s just start working when disassembled and put back again,but with a lot of BSOD when i tried to install W10,sometimes it is working completelly fine unless switched off.
              I tried to make some pressure on CPU BGA socket,but no change of behavior.
              BIOS has been programmed,also BIOS chip was changed and still nothing.
              Not working board just...
              06-30-2022, 12:53 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              Yesterday, 03:47 AM
            • protocold
              MacBook Pro 15" 2010 820-2850 intermittent charging
              by protocold
              I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
              I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
              when it is not intermittent:
              PPVBAT_G3H_CHGR_R is 12.07v
              when it is intermittent:
              When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
              when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
              data line on the battery...
              07-25-2025, 08:18 PM
