Samsung PS43D450 Plasma - Very strange VS and VA?
  • mrpipes3
    • Nov 2017
    • 7
    Re: Samsung PS43D450 Plasma - Very strange VS and VA?
    So I have a similar problem. Originally I had no power. Took the back off look at all the caps, nothing obvious. The the power came on and I had sound but no picture. I replaced the board where you plug HDMI cables, and the logic board. Still sound but no picture. Then I switched back to my original HDMI board and logic board. Still sound no picture. I just got a new power supply today and it reads around 70 max on the VS. VA reads good. The sticker says VS should be 208. The TV powers on....no sound or picture and shuts off after clicking. I adjusted the VS up and down and still about the same reading of 70. I have used X and Y boards. Should I put them in? Would a bad X or Y board cause a low VS reading? Which board should I try first? Thank you!
      How are you measuring Vs? It sounds like your power supply is bad, but the low reading can be caused by a cheaper multimeter that is subject to interference from external sources, like the TV. Can you borrow another multimeter for a "second opinion"?
      • mrpipes3
        • Nov 2017
        • 7
        So I'm an idiot. I was testing the VS and VA in AC mode. I stuck my original components back in and a new (used) x sustain and (used)y sustain board. I tested with multimeter in DC and the VS and VA check out. Only think is I ripped the ribbon on the x sustain board when putting it in. Thoughts?
          Put the ribbon back in and try it again? Did you damage the actual ribbon? They are removable.
          • prince_akg
            • Sep 2017
            • india
            #45
            I am trying to find solution for my samsung plasma model 42" SD s4.0 ...No picture , with in a few sec smps relay clicking sound comes turning gree led indication to red.
            have checked smps (LJ44-00092E) voltage leves, only low voltage are maintained (Vg,D5V,D3V3,12V-amp ,A12/D12,Vt,5v-STB, except Va=70v but all other high voltages are 0 or equivalent, , Vs,Vscan,Vset,Ve =0v
            • r2d2hp
              • Jan 2021
              • 7
              • United Kingdom
              #46
              I have a similar problem to pin6pts and wondered if he ever resolved the problem.
              Yesterday I was watching my PS59D6900 and there was a crack sound and the TV powered of and then came back on but screen is blank. The remote still works and can change channel, level, and power of the TV but its not possible to turn back on and the standby light is off. If I cycle power the TV comes back on. I then took the back off and checked some voltages and found VS,VA & VS_on are 0V. If I check the voltages after recycling the power I can see they are there for about a second. Any thoughts on what might be wrong? thanks
              • zens electronics
                • Jan 2021
                • 31
                #47
                Hi
                These D series Samsung plasma sets are notorious for panel failure .
                Had them fail as you described , with a small crack .
                Regards Xen
                • zens electronics
                  • Jan 2021
                  • 31
                  #48
                  Just to clarify , i'm refering to the PS43D450
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #49
                    With the set off use you meter and check the resistance between VA and ground and Vs and ground.
                    • r2d2hp
                      • Jan 2021
                      • 7
                      • United Kingdom
                      #50
                      Thanks Dick
                      Found resistance between VS & Ground was 1 ohm. After disconnecting boards one by one traced problem to X-Drive. When I power on now VS & VA rise to normal levels and they decay very slowly unlike before when it dropped to zero immediately.
                      Still not able to turn TV back on once turned off and it does power on immediately when applying power so maybe its got another problem as well.
                      Found an X-Drive board so will update once it arrives
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #51
                        Have you read post #30
                        • r2d2hp
                          • Jan 2021
                          • 7
                          • United Kingdom
                          #52
                          I missed that one Dick, thanks. Will disconnect Y-Drive ribbon cable and see if Voltages stay high.
                          Question for Zens, have you ever known screens to crack on their own or is always as a result of impact?
                          • zens electronics
                            • Jan 2021
                            • 31
                            #53
                            Yes , have on several occasions had plasma displays crack on their on , without any external impact .
                            Normally the inner part of display .
                            This is a phenomenom that i have noticed ever since plasma displays became slimer .
                            Never had this scenario with the older , more chucky displays.
                            • r2d2hp
                              • Jan 2021
                              • 7
                              • United Kingdom
                              #54
                              There was a crack sound before it went off. When the screen cracks does it normally take out the circuit boards?
                              Will have a close look at it tomorrow
                              • zen
                                • 511
                                #55
                                Yes
                                Display normally develops some sort of internal short & can potentially take out buffer boards plus y-s u s .
                                I wouldn't waste any more time on it .
                                • r2d2hp
                                  • Jan 2021
                                  • 7
                                  • United Kingdom
                                  #56
                                  Removed cable as per post #30 and VS&VA rise to correct levels. Remote now also turn TV on/off.
                                  Can not see any cracks on external part of the screen and difficult to see what is behind the metal panel.
                                  Will await the arrival of the X-Drive and see if that resolves the problem
                                  • r2d2hp
                                    • Jan 2021
                                    • 7
                                    • United Kingdom
                                    #57
                                    Well Zen, X-Drive arrived, fitted and all voltages came up. However after about 40 seconds large crack and flash from Z-Drive. X-Drive appears to to be working and VE voltage is good. VSC is bad. Could problem with X-Drive have also damaged Y-Drive. Thinking its probably time to throw in the towel.
                                    • zens electronics
                                      • Jan 2021
                                      • 31
                                      #58
                                      Yes display can take out the Z SUS board also
                                      • r2d2hp
                                        • Jan 2021
                                        • 7
                                        • United Kingdom
                                        #59
                                        I could not give up on her and found a replacement Z-Drive. All fired up but then TV fell
                                        foul of the dreaded boot loop. Sent the main board away for repair to https://www.ebay.co.uk/usr/louise.cole19862012 Service is fantastic - there and back in 4 days. Now working again so fingers crossed she will last a few more years
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #60
                                          Thanks for the follow up. Glad you got there in the end.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
