2 week old 70 Aquos Blink codes!
  • crbn79
    • Feb 2011
    • 64
    So I've had a brand new 70 inch for 2 weeks and while watching netflix the picture cuts out. I hit the power on button on the remote and no picture yet power LED flashes code 22. Any ideas?
    FYI, I'm exchanging it for another new one, simply curious as to what the code means.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: 2 week old 70 Aquos Blink codes!
    here is service manual, no mention of 22 blinks! but it might help ya!
    • crbn79
      • Feb 2011
      • 64
      Thanks for the info will dig through it tonight. Good old Bestbuy saying it will take 1 week for them to replace it......
      Turns out it is 2 fast 2 slow which shows up as "Power supply error 2 (*2) UR+13V error"
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • EazyBone
        Un50cu7000 2 blink oddity *partially solved
        by EazyBone
        I write this to maybe help another with this TV.
        So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
        The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
        03-18-2024, 10:24 PM
      • noonyf
        Sony NSX-32GT1 need blink codes.
        by noonyf
        Hello, does anyone have the blink code for this model? I have the schematic but it doesn't list the blink codes. After the set is on for a minute or two, it will shut down and blink 10 times.
        thanks
        09-18-2020, 09:54 AM
      • Vebririon
        panasonic TX-P50V10E 6 blink led problem
        by Vebririon
        I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
        Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
        I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
        05-17-2025, 10:16 AM
      • dominik0801
        Philips 40PFL8606K/02 won't turn on, blink codes
        by dominik0801
        Hello! Yesterday I picked up the TV mentioned above. Obviously I knew it was bad, I bought it to be fixed.
        Chassis: Q551.2E
        It won't power up, only blinks 2 long, then 2 short on the standby LED. Then repeats till you pull it out from the wall. I checked the manual and it states a bad SSB, but I don't just wanna give up already.
        Before I did anything, ofc I checked PSU voltages, all were fine. They were not unstable or anything. (however, 3.3 would stay at 2.9 - 3V constantly, is it bad?)
        Then I tried is to pull everything out of the...
        10-30-2020, 09:58 AM
