Hi all, my Sammy LE40M87BDX has some fixed diagonal lines across the lower half of the screen which is similar to the securityman thread. Number 12 on the service menu says 'reset' which I presume is the factory reset? Should I try this first? The lines do not move, I've not taken a look inside yet.
Samsung LE40M87BDX - Diagonal lines across lower half of screen
Tags: None
Re: Samsung LE40M87BDX - Diagonal lines across lower half of screen
If the lines do not move, I would presume LCD failure.
RESET may be the best option.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Just performed two resets but, the lines are still there. If it's LCD failure then, do I presume the panels bad? Don't suppose PixelProtector DVD will fix it, maybe I'll give it a go?Comment
It looks like the screen has been laid down on something or something put on it when flat. I have seen it on a smaller scale and tried a pixel repairer but it did not work. It was less obtrusive on mine and kids had it in their bedroom.
I think it is permanent damage to the panel.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
That's a shame, the TV is full HD and apart from these lines, the picture is really good. Maybe not viable to replace the panel due to cost, even if I could find one? May end up keeping it as a spare or selling internal parts on that well known auction site!Comment
Re: Samsung LE40M87BDX - (Diagonal?) lines across lower half of screen
Bump! Don't want to hijack this thread but my TV (same model) seems to have the same problem and I have some interesting details.
TV first showed short coloured area over multiple lines approx. 5cm wide and less than a centimter high, consistent with an impact (because children reported that a toy was thrown at the screen)
The area widened very slowly over several months. And at the same time sporadically the TV started the Samsung typical on/off-switching sometimes longer, sometimes shorter periods but always stopped after minutes (or hours) Also the intervals appeared to be arbitrary in length.
After moving house I initially didn't notice when we saw that the problem was completely gone, the picture clear as when new (bought about April 1997 for 1299 pounds w/ a DVD recorder) However, the onf/off-switching intensified in an unpredictable manner.
Only after several weeks the "impact" spot re-appeared and over the next week widened slowly but steadily into the fixed lines you can see on the attached photo.
I hoped to find some bulged capacitors but after removing the backplate and removing the power board everything looks mint to a visual inspection. Don't want to exchange the 1000uF 10V (1x) and 25V (2x) capacitors just out of suspicion and have currently no 47uF 50V (3x) ones as mentioned above in the thread.
Any news, problem found or even fixed??!
RegardsComment
by rfxcaseyI have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
05-16-2024, 06:52 AM -
by GobonTalBzarI have a Samsung UE46F6500 SDXZT with the bottom half of the screen showing purple lines and sort of a lower resolution. These lines appear and disappear in response to motion on any part of the screen. For example they will appear below any popups (no signal etc) and moves sideways to stay below the location of the popups. Screensh1.jpg and Screensh2.jpgshows the issue and Samsung_Problem.zip is a video of the issue as it happens.
I've tried replacing the TCON board but nothing changed. Wiggling the connections doesn't seem to affect anything on screen.
I've attached... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by GjacksonHi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...01-31-2022, 02:25 PM
by ItalianSatHello Everybody,
I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
Moreover, I detached the T-CON board for a new round of investigation. I personally... - Loading...
