Samsung LE40M87BDX - Diagonal lines across lower half of screen
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Hi all, my Sammy LE40M87BDX has some fixed diagonal lines across the lower half of the screen which is similar to the securityman thread. Number 12 on the service menu says 'reset' which I presume is the factory reset? Should I try this first? The lines do not move, I've not taken a look inside yet.
    Re: Samsung LE40M87BDX - Diagonal lines across lower half of screen
    If the lines do not move, I would presume LCD failure.
    RESET may be the best option.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      Just performed two resets but, the lines are still there. If it's LCD failure then, do I presume the panels bad? Don't suppose PixelProtector DVD will fix it, maybe I'll give it a go?
      • selldoor
        Slow Learner
        • 7870
        It looks like the screen has been laid down on something or something put on it when flat. I have seen it on a smaller scale and tried a pixel repairer but it did not work. It was less obtrusive on mine and kids had it in their bedroom.
        I think it is permanent damage to the panel.
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          That's a shame, the TV is full HD and apart from these lines, the picture is really good. Maybe not viable to replace the panel due to cost, even if I could find one? May end up keeping it as a spare or selling internal parts on that well known auction site!
          • MM9800S
            • Apr 2013
            • United Kingdom
            Re: Samsung LE40M87BDX - (Diagonal?) lines across lower half of screen
            Bump! Don't want to hijack this thread but my TV (same model) seems to have the same problem and I have some interesting details.
            TV first showed short coloured area over multiple lines approx. 5cm wide and less than a centimter high, consistent with an impact (because children reported that a toy was thrown at the screen)
            The area widened very slowly over several months. And at the same time sporadically the TV started the Samsung typical on/off-switching sometimes longer, sometimes shorter periods but always stopped after minutes (or hours ) Also the intervals appeared to be arbitrary in length.
            After moving house I initially didn't notice when we saw that the problem was completely gone, the picture clear as when new (bought about April 1997 for 1299 pounds w/ a DVD recorder) However, the onf/off-switching intensified in an unpredictable manner.
            Only after several weeks the "impact" spot re-appeared and over the next week widened slowly but steadily into the fixed lines you can see on the attached photo.
            I hoped to find some bulged capacitors but after removing the backplate and removing the power board everything looks mint to a visual inspection. Don't want to exchange the 1000uF 10V (1x) and 25V (2x) capacitors just out of suspicion and have currently no 47uF 50V (3x) ones as mentioned above in the thread.
            Any news, problem found or even fixed??!
            Regards
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • rfxcasey
              Vertical Lines on Half of LCD Display
              by rfxcasey
              I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
              05-16-2024, 06:52 AM
            • GobonTalBzar
              Samsung UE46F6500SDXZT - Lower half of screen moving purple lines.
              by GobonTalBzar
              I have a Samsung UE46F6500 SDXZT with the bottom half of the screen showing purple lines and sort of a lower resolution. These lines appear and disappear in response to motion on any part of the screen. For example they will appear below any popups (no signal etc) and moves sideways to stay below the location of the popups. Screensh1.jpg and Screensh2.jpgshows the issue and Samsung_Problem.zip is a video of the issue as it happens.
              I've tried replacing the TCON board but nothing changed. Wiggling the connections doesn't seem to affect anything on screen.
              I've attached...
              10-17-2020, 12:11 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • Gjackson
              LCD Tv starts to display black horizontal lines after half an hour of use
              by Gjackson
              Hi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...
              01-31-2022, 02:25 PM
