Sharp 21V-L80M Color TV
  • peterpan271
    • Jan 2011
    • 12
    The remote start of my Sharp 21V-L80M Color TV is taking too long. The display appears approx 15 to 20 secs after the power button on the remote controller is pressed. Where should i check for the problem?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Sharp 21V-L80M Color TV
    How did the problem start and how long ago - how long did it take originally.
    How long does it take using the buttons on the tv. New batteries in the remote?
    On you last two threads you did say you would report back but never did.
    It does not inspire people to be helpful.
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • SONY_E-WASTER
      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
      by SONY_E-WASTER
      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
      does...
      12-26-2021, 05:46 PM
    • cm0002
      Sharp LC-55N7000U 1 long 5 short blinking, no display
      by cm0002
      I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
      Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
      I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
      06-19-2023, 06:21 PM
    • Charrlie
      Sharp Lc-70le734u blinking 2 long 5 short
      by Charrlie
      Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
      So I busted into it and have done the following:
      -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
      07-07-2022, 02:02 PM
      HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
      This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
      09-06-2024, 08:23 AM
